Changed LAN IP, now getting invalid username/pw
AlbumMan
This happened the last time I did a factory reset and don't remember what it took to fix. While manually configuring my simple settings after a flash update, I changed the 192.168.50.1 default back to 192.168.1.1 (which of course changes the DHCP pools) and when the logon GUI appeared, it would not accept my name/pw. Firefox browser cleared but no change. Any ideas? Thank you.
Have you tried with a different browser? Browser to GUI issues are quite frequent lately.
Thanks for the reply @Tech9. No I did not try a different browser and honestly did not think to do that. Since I made a backup on beta3, I restored that and all is back to normal. Other than having one node and now an IoT VLAN, my config is simple; no scripts, mods, USB, etc. I may try another reset if 3006_102.4_0 acts up but I know it won't.
