Check sum verifier
RAJ
Merlin provides SHA256 checksum for downloads. But.....
I can't seem to find a simple portable hash program that will compare sha256 string to the file I download.
I get the file then I run MD5 checksum, hashtag, or digestIT to create the checksum. But then I have to manually eyeball the results to compare to his tag.
Those programs can compare a MD5 checksum string to a downloaded file but none of them can do a sha256 checksum string compared to a file.
Anyone know of a application that can? Web sites don't count, I want a portable program not a website.
http://implbits.com/products/hashtab/
Simply copy the checksum and when you right click on the downloaded file and select the Hashtab Tab, it will show a green checkmark for a match or a red 'x' for a non-match.
See the screen shots in the link above and download the program for free.
Thanks! I had tried hashtab but I could not paste into that slot and so moved on to another program. I found out why. Webroot (my AV program) was blocking another program that also happened to be blocking cut n paste to hashtag but still worked for pasting into notepad. Goofy error.
Thanks again, yes its working fine now!
I use this one:
https://raylin.wordpress.com/downloads/md5-sha-1-checksum-utility/
  • Like
Reactions: tim
