In Samba settings on the router try using the "force as master browser" setting to yes.Never had this problem using AC87U, same setup same USB drive used.
When I move the same file to WD network drive it's streaming fine.
Any idea what can cause this? The movie starts, will play fine for couple seconds then it stops for couple seconds and so on
Many thanks for the prompt reply! Will try thatIn Samba settings on the router try using the "force as master browser" setting to yes.
Well, finally had some time to try that, and unfortunately it still does the same pauses like beforeIn Samba settings on the router try using the "force as master browser" setting to yes.
Try a different usb stick.Well, finally had some time to try that, and unfortunately it still does the same pauses like before
Any other ideas what can cause this?
It's exactly same stick as I had before on the AC87, but I'll tryTry a different usb stick.
My point being the drive may have developed problems, or the firmware doesn't like it anymore. Something like that, never hurts to try different stuff. If not just for comparison.It's exactly same stick as I had before on the AC87, but I'll try
So, tried new USB3.0 stick and still the same problem.My point being the drive may have developed problems, or the firmware doesn't like it anymore. Something like that, never hurts to try different stuff. If not just for comparison.![]()
You could ask @Adamm he has had success with a script that gets samba speeds both read and write up a little higher. I'm not sure if this will help but, the other question I have for you is: Do you have a active swap file on your AC86U?So, tried new USB3.0 stick and still the same problem.
Tried both USB ports, the 3.0 is slightly better but it still stops.
Took out the ac87 out of retirement ( dead 2.4ghz band) and it still works fine.
What gives?
Hmmm, I guess I don't, where do I set it up?You could ask @Adamm he has had success with a script that gets samba speeds both read and write up a little higher. I'm not sure if this will help but, the other question I have for you is: Do you have a active swap file on your AC86U?
You need to ssh into your router. You can do that with a terminal client like putty. Have you ever done anything like that before?Hmmm, I guess I dont
Yes I did, many times, but always followed instructionsYou need to ssh into your router. You can do that with a terminal client like putty. Have you ever done anything like that before?
Ok, ssh into your router and install AMTM. Once its installed and running look for the swap feature. Should be "sw" it will ask you how large of a swap you want, In your case choose 1gig. Once its done, that's it. Reboot the router and try the usb file situation you have again. The swap may help that work better.Yes I did, many times, but always followed instructions![]()
This is the location of AMTM: https://www.snbforums.com/threads/amtm-the-snbforum-asuswrt-merlin-terminal-menu.42415/Yes I did, many times, but always followed instructions
When switching to this router I used SSH to move my DHCP client list
Thanks for your patience, will report back when done !Ok, ssh into your router and install AMTM. Once its installed and running look for the swap feature. Should be "sw" it will ask you how large of a swap you want, In your case choose 1gig. Once its done, that's it. Reboot the router and try the usb file situation you have again. The swap may help that work better.
You never said what method you're using to "stream" the files. All of the discussion has been based on the assumption that you are using Samba to share the files across your network. If that is the case then Samba tends to need quite a lot of RAM to achieve any sort decent file transfer speed. It's possible that you are running other add-ons on your router (like torrents, etc.) that are consuming enough of your RAM to have a performance impact of Samba. Adding a swap file would help to alleviate that problem by increasing the amount of virtual memory.Still puzzled how is this possible when the router is overall way faster then the AC87.
Yes, I use torrent downloader, but always make sure that it's not active when trying to use the file that was downloaded ( did the same on the AC87)You never said what method you're using to "stream" the files. All of the discussion has been based on the assumption that you are using Samba to share the files across your network. If that is the case then Samba tends to need quite a lot of RAM to achieve any sort decent file transfer speed. It's possible that you are running other add-ons on your router (like torrents, etc.) that are consuming enough of your RAM to have a performance impact of Samba. Adding a swap file would help to alleviate that problem by increasing the amount of virtual memory.
So is Kodi accessing the files using Samba, as opposed to NFS or DLNA (media server)?I use KODI on MiBox AndroidTV box to stream the file. The AC87 never had any problems to stream even large DVD rips or 4K mkv
Yes, that's correctSo is Kodi accessing the files using Samba, as opposed to NFS or DLNA (media server)?
Thread starter | Title | Forum | Replies | Date |
P | Basic question on usericon files | Asuswrt-Merlin | 0 | |
RT-AX88U Pro installation from RT-AC68U config files | Asuswrt-Merlin | 12 |
Welcome To SNBForums
