Cisco 871-K9 the internet cannot work, but can get intranet IP?
network
I was a green hand on Cisco networking, and have purchased a Cisco 871-K9 recently for reserch from www.3anetwork.com. I have configured SDM and CCP, but cannot configure PPPoE, only have DOS configuration and finally I can configure the PPPoE for the extranet, but i don't know how to configure the intranet, who can tell me? And attached my configuration, 0-3 port for LAN; 4 port for WAN. My attention was 192.168.1.1 for gateway, intranet DHCP 192.168.1.100~192.168.1.253, dailing was WAN port, while the problem was, the IP address cannot be get for intranet, and the IP manually specifying was 192.168.1.100, the data cannot be received, was 0, network cannot work.
Router#show running-config
Building configuration...
Current configuration : 1885 bytes
version 12.4
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.1.254
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp pool 1
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 192.168.1.1 114.114.114.114
ip name-server 8.8.8.8
ip name-server 192.168.1.1
ip name-server 61.177.7.1
ip name-server 114.114.114.114
vpdn enable
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 192.168.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Vlan1
no ip address
ip nat inside
bridge-group 1
bridge-group 1 spanning-disabled
interface Dialer0
ip address negotiated
ip mtu 1492
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp pap sent-username 12312341234 password 0 555555
ip route 0.0.0.0 0.0.0.0 Dialer0 permanent
ip dns server
no ip http server
no ip http secure-server
ip nat pool pool1 192.168.1.0 192.168.2.0 netmask 255.255.252.0
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 0.0.0.0 255.255.255.0
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
