Config Guest Network on RT-N66u in AP Mode
Gapmn
Is it possible to have the N66u use a different subnet for the guest network in AP mode. If so, how would I do that?
yes! N66u Is it possible AP mode
I tried it and I still receive an ip with the same subnet. That is why I am asking.
In AP mode the device no longer controls the network at the IP network layer. I think the guest network and wireless client isolation features do not work unless the device controls IP.
Off topic since not separate IP subnet that OP wanted, but there is a partial solution to Guest isolation on Asus in AP mode.
See http://forums.smallnetbuilder.com/showpost.php?p=166259&postcount=24
(That thread's topic was Guest Network: Not restricting local network access )
Note if you change the AP's configuration without a reboot, the script needs to be rerun manually.
