Configure "Wireless Router" mode behind Network
Cooldragonex
Hello, I have a new Ubiquti Edgemax Lite 3 Router that i plan to set it up as my main router.
Was wondering is it possible to setup up my secondary router, which is a RT-AC56U to run on "Wireless Router" mode behind my Edgemax Lite 3, so that i could use the full functions such as parental controls, network protection, etc in the router instead of running on "Access Point" mode which only has limited features.
If it is possible, what are the settings i need to disable other than DHCP, NAT, UPnP and WAN?
Thank you in advance for your help!
Javier
There are many ways depending on many factors. I believe double NAT should work (LAN IP as WAN IP on secondary router - like LAN in LAN)
Odesláno z mého SM-G935F pomocí Tapatalk
Set the Asus to AP mode. Ethernet connect the Asus to a LAN port on the ERL, or a switch connected to a LAN port on the ERL..
