i have an 8 port poe switch. 4 ports are poe. i need more poe ports so if i buy another switch and connect the 2 will i run into problems or signal lose? i figured by buying another small switch it would be cheaper than buying a 12 or 16 port poe switch.
for what it is worth the poe is for my network camera.
