Connection Speed issues with RT-N66u
bluelightning
Hello ,
I just setup my Rt-N66u router yesterday and I am having connection speed issues with. I am getting about 10-15 db stronger signal than my existing routers when measured with inSSID in both bands ( compared to a belkin dual band router and a D-link 655 router), however in the wireless network connection status it is only indicating a speed of 54Mbps, compared to the 130/150 Mbs with the previous routers. I have examined this on two laptops with similar behavior. I am using a bigfoot 1102 ( 2 antennae) wifi card in one laptop and a generic (I think Realtek) 2 antenna card on the other. Both of which laptops behave just fine with the other two routers.
Thinking that this might be just an issue with the status I connected a 3 TB external Hard drive via USB and tried transferring some large files wirelessly and the download rates are similarly slow . I am getting 20Mbps transferring files wirelessly @5 GHz. Connecting via gigabit ethernet I get about 40Mbps. (5 MB/s as displayed by Windows)
Is there something I am missing or do I just have a defective unit that I need to return ?
I have the latest firmware .108 which I flashed , then reset the configuration, rebooted, reconfigured etc.
Bandwidth 20/40 Mhz set
Tried with Channel , fixed in a few positions as well as auto.
Thanks for any help or suggestions
Hello ,
Him
If you set mixed mode, or did not set WPA2 AES on security set up. it may slow down. Just try -N mode only with WPA2 AES set up. As well check if you have newer driver for the WiFi cards.
Thanks for your reply. I am currently set to N only with security settings of WPA2 AES-TKIP. The bigfoot 1102 installed in one laptop is pretty recent. I will try to see if there is a newer driver available though.
N spec requires you to use WPA2+AES to get most thoughput, anything else it will drop you to 54mbps which is expected. In most env 20MHz channel works best for a 2 radio system rather than a channel bonded 40MHz.
That fixed it.
Thanks to both of you. The default setting has AES-TKIP and wireless mode set to Auto. Changing to WPA2 & AES did fix this problem. For a while I was wondering if I had a defective router with only 1 antenna working. Forgive my ignorance on this.
Now I need to figure out why I am getting slow transfer rates with my 3 TB external Hard drive connected via USB. Currently I am getting about 5 MB/s read and something like 760 kB/s write speeds. This is a relatively new HD with USB 3.0. Any suggestions ?
