RT-BE92U super slow WIFI
Thanks everyone, i am sendjng it back but to answer a couple of questions.
I am on 5 acres so plenty of space around me. The only other 5Ghz is the network i have running. I have changed channels and can see that the signals are not overlapping. The 95% utilisation was at the furtherest point away and reduced to 20 ish when right next to it, which still only get to a max of about 2/3 of the speed of the old clunker.
The 2.4G signal is odd too it suffers more the further i move away than the 5G. I can still connect to the 5 G at the furtherest test distance but the 2.4G cannot be seen at all.
I had a quick look this morning but i didn't find the location, where might it be hiding?
OK yeah then it's defective. Good call. "Self interference" is a type of hardware issue. Something not grounded properly, etc.
PS: envious of all your space. 😁
Cheers.
@kazafog
Here is an observation. On my Google Pixel Pro 10, I immediately get the max speed while connected to the BE92U but on my laptop which has an Intel BE200 WLAN Card. I was getting 200-480 MBPS only. I tried a few times but the result was the same although I could've sworn I saw it hit near 800MBPS in the past.
MLO is and was always enabled so that's not my issue.
Since someone mentioned their hardware revision, that made me check my main BE92U; turns out it's v4.5 while the router downstairs (the AiMesh Node) is on v1, which I have recently swapped, as that old BE92U was the main router before I recently got this other BE92U. So I was thinking hmmm, perhaps the V1 was better? Just before I thought of resetting everything and swapping them out, I though hey, let me do another test and what do you know, now I get 943MBPS on the laptop, the same speed I get when connected via Ethernet.
So my observation is, it takes some time for the laptop to connect to the right channel and band.
Since someone mentioned their hardware revision, that made me check my main BE92U; turns out its v4.5
Since this got brought up I'm now obsessed with it which is typical for me. I've read that the v1 to v3 (I have v3) are the "bad" ones. Mostly thermal issues. And I have seen RT throttling in the logs in the past during early morning hours when I'm sleeping and no high utilization on network. I've also seen kernel PKT messages around the same time each morning making me think of possible AiProtection stuff. It does seem to be better when I turn off AiProtection in the sense that I get less of the PKT messages. We aren't talking DROP messages, just kernel PKT with a series of packet dump contents. Also will get DDD messages with signal corruption events, etc. I had previously thought oh this is a driver or software issue now I'm like WTF is it hardware? I probably shouldn't obsess because there have been no reboots and no network issues. I've never seen my CPU temp go above 53 degrees which is low compared to the HW thresholds for thermal events.
I get full speeds and don't have any user experience issues just see it in the logs every now and again. Apparently in 2025 they went from at least version 3.0 to version 5.1 to me that says a lot of hardware revisions in one production year. Eesh.
I've been an ASUS router user & Merlin user since 2016. This be my 3rd ASUS router in 10 years as they have lasted quite a while. I only upgraded to the BE92U for the 6ghz band. I didn't need to upgrade I just want more airspace to myself. :)
I never had an issue with my v1 by the way, it was perfect from day one. The only reason it went to another room as a node is because I bought a BE19000 2 months back so I put that as the main one then I refunded it a few days ago as it was not giving me more than 80 MBPS and the signal was only 2-3 bars out of 5 even with me sitting right next to the router, it might've been a lemon but it's not worth double the price of the BE92U even though it is superior in every way on paper so now that I got another BE92U which is v4.5, I just put that as the main router instead of the BE19000. Heck, I didn't even know about these revisions and never checked until someone mentioned it today otherwise I would'v never known.
Same. It was me who brought it up trying to help the OP (it looks like he has bad HW and is returning it). I regret looking at the sticker now. 🙇‍♂️ I would never have known otherwise.
I'm not with my unit at the moment, but from memory:
- About half way down, the left hand side of the settings screen, there's a tab called WIFI something. Located around the LAN and WAN tabs. Click on it.
- You'll now see a series of WIFI related tabs (horizontally). The first tab has some basic settings. I don't think it is on this first tab.
- Look for the "Professional" tab along the top and click on it.
- This will open a series of WIFI settings that will either ruin your wifi experience or make it marginally better. I think the location drop down lower down this page. For me, it was set to Asia by default, but being in Australia, I thought it would be better to set it appropriately. It doesn't matter which channel you have selected at the top of the screen (2.4, 5 or 6) the location setting once applied for 1 channel will flow across to the other channels. Make sure you click apply after the setting change. This will restart the radios, but not the router.
Hope those vague instructions helps some one.
Going off topic, I bought a HW ver.1 model not long after it first came out in Australia. That was about May '25, which was nearly 6mths after release in other markets, so I'm surprised to see they're over V4 now. A lot of revisions in such a short space of time! Probably mostly component and component supplier changes, rather than major revisions.
GJ
GJ
It looks like that's not an option there. It seems that the country/region to apply regulatory settings for WiFi is done during initial setup where it detects your location. To reset it you must do a factory reset and go through the initial quick setup screen again. In the OP case it does appear to be a HW issue and he is returning the unit.
Pertaining to the HW versions: I agree it's a lot of revisions in one year.
GJ
There is no such setting for region.
I only see the region under Administration Tab but that's just for the Time Zone.
I won't be with the router until the weekend, but for me, the "Region" setting appears underneath the Tx Power Adjustment setting at the bottom of the screen.
The below screen print is from an older fw (3.0.0.6.102_37563) and from the 2.4GHz page, but is generally what it looks like:
(Do not reduce the Power Adjustment, like I have done here!)
I think what @Tech9 said about the setting only appearing for certain regions might be correct. From my shady memory, only Asia Pacific locations appeared in the drop down. What determines if you are in a specific region, I have no clue.
I'll take a look when I get back there on the weekend and post an up to date screenshot for reference.
GJ
The firmware is Global, the devices are Region hardcoded. In different regions different settings and even menus appear in GUI. Folks in China for example have an additional main page menu. @GJJ may eventually see it appearing if there is China option in the drop down menu. It's there on all routers, just hidden.
i feel better now, the router is on the way back to where it came from.
Just wanted to say thanks for all your input. Asus is out and Ubquiti is in my sights now. Now I just need to learn what is what and start saving.
If your 3x Technicolor units work well for you I don't see the rush to upgrade. They are AC-class devices, but 400Mbps on 5GHz and 40Mbps on 2.4GHz is excellent for mobile devices. The bandwidth you get to Internet via Starlink is also excellent. I can help you with Ubiquiti hardware in case you really want to upgrade.
Cheers, thanks for the offer, i have been reading a fair bit to try to get my head around their products, their naming is definitely not made to be simple. But i will keep reading and see how i go for now, i might reach out down the track if thats cool. I am still unsure if my bank account and wife will like it much but..... no harm in looking for now though.
Actually one thing, i was thinking, i may be able to dip my toe in and grab an outdoor AP, will they cross polinate ok? i presume so but .... ASSume.
A plain vanilla AP is router agnostic. It is just another LAN device to the router. If you were doing VLANs it might get trickier.
Look at TP-Link OMADA smb gear for a little bit more budget friendly offering.
I know this thread is pretty much over with, but thought I might show screen prints from the current fw, 3.0.0.6.102_38980, with the Region setting and the options within it, for reference if necessary down the path.
