Constant log noise for DHCPOFFER and DHCPDISCOVER System Messages for single device (video doorbell)
Gen10
Nov 21 15:05:17 GT-AX6000-1337 dnsmasq-dhcp[30878]: DHCPOFFER(br52) 192.168.10.150 <mac address>
Nov 21 15:05:40 GT-AX6000-1337 dnsmasq-dhcp[30878]: DHCPDISCOVER(br52) <mac address>
For whatever reasson I get non stop spam like this in the logs (upwards of 10 times a minute), assigning a static IP or moving it off a the guest network pro VLAN back to the main network does not resolve it. Neither does rebooting the device or the router. Its a Eufy Doorbell that uses a chime homebase for storing the doorbell recordings locally connecting via Wi-FI.
What is the RSSI value ( -xx dB ) for the wifi band used at the doorbell wifi antenna with the door closed ?
Did you search the forums for "eufy" ?
Which firmware version are you using? I have the same problem with guest network pro and my Sonos speakers. Dhcpoffers/dhcpdiscover in an endless looop. The problem disappears when I disable my guest networks.
I also have the same issue with my Marstek Venus battery, constant DHCP offer messages, it's binded to the nearest mesh node, wifi signal is excellent... Is there a solution for this
-39dbm
I started getting this noise and in-app showed Device Offline.
I reconnected Ring Doorbell by reconnecting thru Ring app - hit setup button on doorbell, this will get white ring and follow in-app directions. As there was no change to SSID and password it simply connected without prompting for password again.
