CPU Load Percent
Glenn Freidet
Does anyone know if the CPU load percent is being calculated, or does it come directly from SNMP? I can't find an OID that works for load percent, just the usual 1-5-15. If it's not SNMP, can you point me to it in the code?
Thanks.
-G
Thanks.
-G
It's probably somewhere in httpd, if you are referring to the load shown on the networkmap (first page). I can't point you exactly to it, I never really looked at that part of the code (it was added by Asus).
It's definitely not through SNMP, probably a /proc interface or through a kernel call.
That's exactly what I needed to know. Thanks Merlin.
