Cron job to reset VPN in slot 1
Viktor Jaep
Part of the Furniture
Hi All,
I'll admit... I'm just not good at this scripting stuff... but what I am looking for is your help/advice on what it would take to automatedly run a cron job at a specific time each night to simply stop/start or restart the VPN client in slot/instance #1.
I figured out that the cron script piece would need to say: 0 01 * * 1-7 -- executing at 01:00 every day of the week... but I'm not sure what script (if any) relating to VPN slot #1 I could execute in order for this to happen, or if it would need to be created?
I appreciate your help, and I appreciate the learning opportunity here! Thank you in advance...
Using "1-7" for days is non-standard and therefore bad practice. days should range from 0 to 6, but as you want "all days" you might as well use "*" instead.
I can't help you with the VPN command though. :(
LOL.. thanks! So much for being proactive and using the Crontab expression editor! :)
Ha! I've been doing crontab entries for over 20 years. It's burnt into my brain. :) (To be fair that website does say in red that your command was "Non standard! May not work with every cron." )
Does this do what you want if you enter it from the command line?
service restart_vpnclient1
Yes, thanks -- that does the trick! So is it just a matter of running a command like:
0 01 * * * /jffs/scripts/service restart_vpnclient1
And this will survive a reboot, right?
No you have to use the cru command and put it in a user script.
Add the following line to the end of your /jffs/scripts/services-start script (assuming it already exists).
cru a vpn1 "00 01 * * * service restart_vpnclient1"
Thanks a bunch, Colin! That was super helpful! Learned all about how VI is very unuserfriendly, and how nano was much easier to edit files with too... ;) I really appreciate this... will check the logs tomorrow AM and see how it fared!
BTW you do have to reboot the router for that services-start script to run. ;)
Ahh. I was trying to figure out why nothing happened at 1am according to the logs... ;) Good call... it's been rebooted now... let's see what happens tomorrow!
You can check that the services-start has run correctly by looking at the router's crontab. Enter the following command and you should see your entry:
cru l
(That's a lower case letter "L" not a number "1")
