Help with cron job not runnning
TheHighFlyingBirds
First post and novice, so go easy on me.
I'm using an ASUS RT-AX86U pro with merlin 3004.388.4 FW. I am trying to get a cron job running to check a VPN connection, and re-instate it if it has failed.
I have enabled the "enable jffs custom scripts and config" option.
I have created a script > vpncheck.sh which is located in /jffs/scripts and runs fine manually. Script is:
#!/bin/sh
# check state of VPN client1
#if = 0, VPN is down
#if != 0, VPN is running
if [[ $(nvram get vpn_client1_state) != 0 ]]
then
        echo "VPN Running - test last run at $(date)" | tee output.txt
elif [[ $(nvram get vpn_client1_state) == 0 ]]
then
        service start_vpnclient1
        sleep 10
        if [[ $(nvram get vpn_client1_state) != 0 ]]; then
                echo "VPN Restarted Successfully - test run at $(date)" | tee output.txt
        else
                echo "VPN Failed - test last run at $(date)" | tee output.txt
        fi
fi
When I run it manually it updates the output.txt file accordingly, and if the VPN is down, it reconnects it.
I have also created a services-started file, which contains the following:
#!/bin/sh
# This cript get called after all other system services
# have been started at boot on router
# cron job to run vpn check script - this ensures cron task is started following reboot
cru a vpncheck "*/1 * * * * /jffs/scripts/vpncheck.sh"
I have applied chmod 777 to all three files in scripts folder, such that they are all -rwxrwxrwx
I then added the cron task using the following:
When I check the cron file in /var/spool/cron/crontabs/{my username} it shows up, with the output being:
*/1 * * * * /jffs/scripts/vpncheck.sh #vpncheck#
*/2 * * * * /etc/openvpn/server1/vpn-watchdog1.sh #CheckVPNServer1#
46 9 */7 * * service restart_letsencrypt #LetsEncrypt#
The task remains after a reboot. However, it just doesn't seem to run, as the output.txt file does not change and if I turn off the vpn it does not restart it. I cannot see any mention of cron in syslog.log, and doing a search of the other tasks also draws a blank.
I have even tried creating a simple cron task using the same approach as above and still nothing.
Can anyone help?
Thanks in advance.
It should be services-start not services-started. I assume that was a typo in your post.
You have not specified a full path for the output.txt file so that might be an issue (it's probably going to /tmp/home/root). There's also no terminal attached to a running cron process so that might also be causing problems for the tee command. I suggest you send all output to a fully qualified file path. For example:
echo "VPN Running - test last run at $(date)" >> /jffs/output.txt 2>&1
Thank you so much @ColinTaylor you are a genius; I have been trying for the last two days to get it working. Yes you were right services-started was a typo in my post. It was the lack of path for the output file that was causing it to not work.
I added the path as suggested and it started working. Replacing the tee with >> makes it add a new line as opposed to overwriting the previous entry.
The next problem is to work out how to have it so it only records the output for a fixed period of time, e.g. 2 weeks, so it will only store the output for the last two weeks, and anything older is deleted. Any ideas on that one :)?
It could get pretty ugly trying to "be clever" and doing it in the script. I think I'd use the KISS approach and setup a second cron job that ran twice a month and deleted the output file.
cru a Delete "01 03 1,15 * * rm /jffs/output.txt"
P.S. I'd also consider running your vpncheck.sh job every two minutes rather than every minute.
Thanks again, I will have a play, but your suggestion seems logical and far easier, which suits me.
Yes already changed task frequency to every 30 mins, only had it at 1 min whilst trying to get it to work.
