QuikSilver
Have been trying to narrow down what the issue may be but would like to hear what others may think. I'm leaning more towards bad Ethernet port on the firetv but curious what others may think.
Problem: Firetv was working fine until recently. I noticed that I would get the Connected but with problems message (when looking into it I get a check mark next to Connected to Ethernet, but Not connected to internet). After trying to troubleshoot it, I finally reset it (firetv) back to factory defaults. Once this was accomplished it still did not work wired. I checked numerous items from Lan DNSfilter settings, to unbound. Nothing made a difference. Finally I tried WIFI and it works fine, no problem. While I understand some of you may think..."Well dang, if it works on WIFI, then go with it", thats not my personality. Even if something is "fixed" I still want to understand the why... Hoping some of you all are as well.
SysLog: Nothing special, changing cables, switching ports on router, etc.....
Aug 17 22:46:24 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 17 22:46:24 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered disabled state
Aug 17 22:46:32 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 100 mbps full duplex
Aug 17 22:46:32 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered forwarding state
Aug 17 22:47:02 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 17 22:47:02 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered disabled state
Aug 17 22:47:03 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 100 mbps full duplex
Aug 17 22:47:03 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered forwarding state
Aug 17 22:48:26 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 17 22:48:26 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered disabled state
Aug 17 22:48:39 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 100 mbps full duplex
Aug 17 22:48:39 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered forwarding state
Aug 17 22:48:40 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 17 22:48:40 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered disabled state
Aug 17 22:48:41 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 100 mbps full duplex
Aug 17 22:48:41 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered forwarding state
Aug 17 22:49:09 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 17 22:49:09 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered disabled state
Aug 17 22:49:27 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 100 mbps full duplex
Aug 17 22:49:27 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered forwarding state
Aug 17 22:49:28 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 17 22:49:28 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered disabled state
Aug 17 22:49:30 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 100 mbps full duplex
Aug 17 22:49:30 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered forwarding state
Aug 17 22:55:38 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 17 22:55:38 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered disabled state
Aug 17 22:55:54 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 100 mbps full duplex
Aug 17 22:55:54 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered forwarding state
Aug 17 22:55:55 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 17 22:55:55 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered disabled state
Aug 17 22:55:56 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 100 mbps full duplex
Aug 17 22:55:57 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered forwarding state
Aug 17 22:57:01 RT-AC86U-AEA8 (unbound_log.sh): 29330 Processed 0 reply_domains...
Aug 17 22:57:01 RT-AC86U-AEA8 (unbound_log.sh): 29330 Processed 0 nx_domains...
Aug 17 22:57:01 RT-AC86U-AEA8 (unbound_log.sh): 29330 Processed 0 RPZ events...
Aug 17 22:59:20 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 17 22:59:20 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered disabled state
Aug 17 22:59:29 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 100 mbps full duplex
Aug 17 22:59:29 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered forwarding state
Aug 17 23:00:22 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 17 23:00:22 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered disabled state
Aug 17 23:00:22 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 100 mbps full duplex
Aug 17 23:00:22 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered forwarding state
Aug 17 23:01:08 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link DOWN.
Aug 17 23:01:08 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered disabled state
Aug 17 23:01:10 RT-AC86U-AEA8 kernel: eth3 (Ext switch port: 2) (Logical Port: 10) Link DOWN.
Aug 17 23:01:10 RT-AC86U-AEA8 kernel: br0: port 3(eth3) entered disabled state
Aug 17 23:01:14 RT-AC86U-AEA8 kernel: eth2 (Ext switch port: 1) (Logical Port: 9) Link UP 100 mbps full duplex
Aug 17 23:01:14 RT-AC86U-AEA8 kernel: br0: port 2(eth2) entered forwarding state
Aug 17 23:01:22 RT-AC86U-AEA8 kernel: eth3 (Ext switch port: 2) (Logical Port: 10) Link UP 100 mbps full duplex
Aug 17 23:01:22 RT-AC86U-AEA8 kernel: br0: port 3(eth3) entered forwarding state
