Custom firmware build for R9000/R8900 v. 1.0.4.35HF
Voxel
Part of the Furniture
Continuation of:
https://www.snbforums.com/threads/custom-firmware-build-for-r9000.40125/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-v-1-0-4-33hf.58296/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-r8900-v-1-0-4-34hf.59011/
New version of my custom firmware build: 1.0.4.35HF.
Changes (vs 1.0.4.34HF):
1. minidlna package is upgraded 1.2.1->1.2.1-2018-04-10.
2. (minidlna) ffmpeg package configuration is changed (to provide more stable support of the FLAC files).
3. (minidlna) ffmpeg compilation flag conflict is fixed (now it is pure Cortex-A15 target).
4. (minidlna) libogg package is upgraded 1.3.3->1.3.4.
5. (minidlna) sqlite package is upgraded 3290000->3300100.
6. expat package is upgraded 2.2.7->2.2.9 (CVE-2019-15903).
7. unbound package (used in stubby) is upgraded 1.9.3->1.9.4 (CVE-2019-16866).
8. DNSCrypt Proxy v.2 is upgraded 2.0.27->2.0.28.
9. dnsmasq package is upgraded 2.78->2.80.
10. curl package is upgraded 7.65.3->7.66.0.
11. haveged package is upgraded 1.9.6->1.9.8.
12. libubox package is upgraded 2019-06-16->2019-10-21.
13. transmission-web-control package is upgraded 2019-04-16->2019-07-24.
14. dropbear package is changed: to allow ssh forwarding.
15. e2fsprogs package: optimization for a size.
16. patch package is added (kamoj add-on, replacement of a busybox analog).
17. coreutils sort package is added (kamoj add-on, replacement of a busybox analog).
18. etherwake package is added (kamoj add-on).
19. busybox: sort and patch are disabled.
20. OpenSSL 1.0.2/1.1.1: make an order with patches.
21. Host tools (mtd-utils): Add: glibc >= 2.28 compatibility patch.
22. Host tools (m4): Add: glibc >= 2.28 compatibility patch.
23. Host tools (squashfs4): Add: glibc >= 2.28 compatibility patch.
24. Toolchain: gdb is upgraded.
25. Development platform is changed (Debian9->Debian10: glib 2.24->2.28; gcc 6.3.0->8.3.0; etc).
26. Support of new certificates for https.
27. QoS could be updated to v1.64 Oct 23, 2019 (press [Update Now] button in GUI).
28. Plex could be updated to v.1.18.0.1913-e5cc93306 Jul 16, 2019.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Voxel.
Anybody here using the R9000. I'm on the R7800 right now but the R9000 is an intriguing piece of hardware, particularly for the ability to do Amazon Cloud backup.
indeed i am and i love my R9000 as it handles my 2gb fiber connection very well for consumer hardware. i dont use the backup on it anymore after amazon became to expense to store my boat loads of data. still it is a nice perc for those that might use it
So is R9000 better in terms of performance than R7800? I have been looking at these two routers for a while and was curious as what the overall verdict was. I see that they have different CPUs but don’t know a whole lot about Netgear.
Spec wise yes the R9000 is twice as powerful comparing to the R7800. I just prefer the R9000 because it has a sfp+ port that can handle my fiber connection above 1 gig speeds, other then that it also has 7 lan ports vs the standard 5 on most things these days. At the end of the day i would say the R9000 is a bit overkill for most people and the 802.11ad on it is useless mostly because it was out of style before it even came to a device in favor of 802.11ax also known as "WiFi 6". For me the R9000 only does my basic routing, i have a seprate sever that does my dns, dhcp, firewall etcetera. My setup is 900% overkill for home users but hey i have bragging rights at work and will never in the foreseeable future run into a speed issue.
