D7000v2
Gapmn
When will the D7000v2 be available for purchase in the USA ?? It will be available for purchase starting 10/9/2017 in the UK and is already available in AU and NZ etc...
why do you want to get the V2 at this stage we have no idea what chipset its using and Most useful FCC documents are under short-term confidentiality until 10/14/2017 according to wikidevi
so if someone known how to intemperate this
see
https://apps.fcc.gov/oetcf/eas/reports/ViewExhibitReport.cfm?mode=Exhibits&RequestTimeout=500&calledFromFrame=Y&application_id=uXHvzm8jnOeH99wsxvEjJw==&fcc_id=PY316400356
might give some sort of indication of what chipsets its using , whats important is the dsl chipset used
SLLFB is a Lantiq (Intel) AnyWAN GRX350.
https://wikidevi.com/wiki/Lantiq#GRX_350.2F550.2F750
This thread suggests that the Intel ARK page for the GRX350 mentioned SLLFB at one time. A cached version on archive.org confirms that.
The radios are probably Lantiq (Intel) WAV513 + WAV523
Very similar to the Phicomm K3C A1
well there you go , as i suspected the v2 is not just a window dressing update of the d7000 its totally different hardware from the ground up , why would they call its the d7000 still ?
They did stuff like this with the WNDR series as well especially the 3700’s revisions with sometimes totally different CPUs. Definitely annoying.
Probably because the capabilities (AC1900) are the same as far as most customers are concerned and it allows them to avoid obsoleting the D7000v1 which is likely still available in the market.
