DDNS Question
Island
Hey fellas. Just wanted clarification. I just swapped my old 3100 to an 86U that I am using as my Mesh router. I got the 86U setup fine and my old 3100 and another 86U are being used as mesh nodes. My question is that before I swapped out the 3100 and reset it to factory, I did release the DDNS from the 3100 so I could use the same name for the 86U.
When I set up the 86U DDNS and put in the same name I click apply and a window pops up saying the name is registered. But I do not see any of the certificates from "Let's encrypt" like it shows on Asus's DDNS support site. Also, on the main network map, next to my DDNS name it has a yellow exclamation, and when I highlight it, all it says is my host name is registered. Does that mean that it worked or that my name is already registered with my old router? Very confusing. Should I just contact Asus?
