DDNS-Start wont autorun?
JoQ
Running Merlin 380.63_2 on my AC68U.
I have setup a Namecheap ddns in the Asus settings, and also created a ddns-start in /jffs/scripts/ (also activated custom JFFS scripts in settings).
The ddns-start looks like this:
#!/bin/sh
 curl -s "https://dynamicdns.park-your-domain.com/update?host=www&domain=mydomain.com&password=mypasswordgoeshere"
 /sbin/ddns_custom_updated 1
And after creating this I ran it, and it updated fine, every subdomain on my Namecheap is updated and working great. But today when I went to a subdomain of mine, I couldn't access it. I could access the main domain (which is in Asus settings).
So it seems like it doesn't run this script after running the main DDNS update?
How can I make sure that this script will be running automatically everytime my IP updates?
It is executable "chmod a+rx /jffs/scripts/ddns-start"
I ran the script manually today and it works great now, but I want to make sure this is automated until next time.
Thank you!
Same thing happened again, today when I went to one of my subdomains, I could not get to my services. So I checked Namecheap and it hasn't updated the subdomains.
The main domain does update without any trouble (because that is the one I have setup in the router UI settings).
My DDNS-Start script wont autorun when the IP is updated.
How do I make sure that it will autorun everytime the IP changes?
Please help me! I have to manually run it every time!
EDIT: When I run it manually the output looks like this (I have more subdomains than what I posted in my first post):
<?xml version="1.0"?><interface-response><Command>SETDNSHOST</Command><Language>eng</Language><IP>IPADRESS</IP><ErrCount>0</ErrCount><ResponseCount>0</ResponseCount><Done>true</Done><debug><![CDATA[]]></debug></interface-response><?xml version="1.0"?><interface-response><Command>SETDNSHOST</Command><Language>eng</Language><IP>IPADRESS</IP><ErrCount>0</ErrCount><ResponseCount>0</ResponseCount><Done>true</Done><debug><![CDATA[]]></debug></interface-response><?xml version="1.0"?><interface-response><Command>SETDNSHOST</Command><Language>eng</Language><IP>IPADRESS</IP><ErrCount>0</ErrCount><ResponseCount>0</ResponseCount><Done>true</Done><debug><![CDATA[]]></debug></interface-response><?xml version="1.0"?><interface-response><Command>SETDNSHOST</Command><Language>eng</Language><IP></IP><ErrCount>0</ErrCount><ResponseCount>0</ResponseCount><Done>true</Done><debug><![CDATA[]]></debug></interface-response><?xml version="1.0"?><interface-response><Command>SETDNSHOST</Command><Language>eng</Language><IP>IPADRESS</IP><ErrCount>0</ErrCount><ResponseCount>0</ResponseCount><Done>true</Done><debug><![CDATA[]]></debug></interface-response><?xml version="1.0"?><interface-response><Command>SETDNSHOST</Command><Language>eng</Language><IP>IPADRESS</IP><ErrCount>0</ErrCount><ResponseCount>0</ResponseCount><Done>true</Done><debug><![CDATA[]]></debug></interface-response><?xml version="1.0"?><interface-response><Command>SETDNSHOST</Command><Language>eng</Language><IP>IPADRESS</IP><ErrCount>0</ErrCount><ResponseCount>0</ResponseCount><Done>true</Done><debug><![CDATA[]]></debug></interface-response><?xml version="1.0"?><interface-response><Command>SETDNSHOST</Command><Language>eng</Language><IP>IPADRESS</IP><ErrCount>0</ErrCount><ResponseCount>0</ResponseCount><Done>true</Done><debug><![CDATA[]]></debug></interface-response><?xml version="1.0"?><interface-response><Command>SETDNSHOST</Command><Language>eng</Language><IP>IPADRESS</IP><ErrCount>0</ErrCount><ResponseCount>0</ResponseCount><Done>true</Done><debug><![CDATA[]]></debug></interface-response><?xml version="1.0"?><interface-response><Command>SETDNSHOST</Command><Language>eng</Language><IP>IPADRESS</IP><ErrCount>0</ErrCount><ResponseCount>0</ResponseCount><Done>true</Done><debug><![CDATA[]]></debug></interface-response><?xml version="1.0"?><interface-response><Command>SETDNSHOST</Command><Language>eng</Language><IP>IPADRESS</IP><ErrCount>0</ErrCount><ResponseCount>0</ResponseCount><Done>true</Done><debug><![CDATA[]]></debug></interface-response><?xml version="1.0"?><interface-response><Command>SETDNSHOST</Command><Language>eng</Language><IP>IPADRESS</IP><ErrCount>0</ErrCount><ResponseCount>0</ResponseCount><Done>true</Done><debug><![CDATA[]]></debug></interface-response><?xml version="1.0"?><interface-response><Command>SETDNSHOST</Command><Language>eng</Language><IP>IPADRESS</IP><ErrCount>0</ErrCount><ResponseCount>0</ResponseCount><Done>true</Done><debug><![CDATA[]]></debug></interface-response><?xml version="1.0"?><interface-response><Command>SETDNSHOST</Command><Language>eng</Language><IP>IPADRESS</IP><ErrCount>0</ErrCount><ResponseCount>0</ResponseCount><Done>true</Done><debug><![CDATA[]]></debug></interface-response>
