Deluge problems
andyvxi
Can anyone tell me if there are currently any problems with installing or running Deluge on Entware?
Until recently, I had this going without a problem, then suddenly, it would no longer start up, offering some messages that my limited experience couldn't understand. It may have coincided with a recent firmware upgrade. After playing around a bit, I just decided to factory reset my AX68U and start from scratch.
Now, Deluge still won't start, and is offering a whole range of new errors.
So it would be good to know if this is a problem with my device in particular or if it's a wider problem and I should not waste my time on it. So, is anyone else experiencing something similar?
Thanks.
Andy
This is what I see now when trying to start Deluge:
xxxxxx@RT-AX68U-9408:/tmp/home/root# Traceback (most recent call last):
File "/opt/bin/deluged", line 33, in <module>
sys.exit(load_entry_point('deluge==2.1.1', 'gui_scripts', 'deluged')())
File "/opt/lib/python3.10/site-packages/deluge/core/daemon_entry.py", line 87, in start_daemon
from deluge.core.daemon import is_daemon_running
File "/opt/lib/python3.10/site-packages/deluge/core/daemon.py", line 19, in <module>
from deluge.core.core import Core
File "/opt/lib/python3.10/site-packages/deluge/core/core.py", line 40, in <module>
from deluge.core.rpcserver import export
File "/opt/lib/python3.10/site-packages/deluge/core/rpcserver.py", line 28, in <module>
from deluge.crypto_utils import check_ssl_keys, get_context_factory
File "/opt/lib/python3.10/site-packages/deluge/crypto_utils.py", line 12, in <module>
from OpenSSL import crypto
File "/opt/lib/python3.10/site-packages/OpenSSL/__init__.py", line 8, in <module>
File "/opt/lib/python3.10/site-packages/OpenSSL/crypto.py", line 17, in <module>
File "/opt/lib/python3.10/site-packages/OpenSSL/_util.py", line 6, in <module>
File "/opt/lib/python3.10/site-packages/cryptography/hazmat/bindings/openssl/binding.py", line 14, in <module>
ImportError: /opt/lib/python3.10/site-packages/cryptography/hazmat/bindings/_openssl.abi3.so: undefined symbol: FIPS_mode
Fixed. It's better to re-install deluge from scratch:
Bash:
opkg --autoremove remove deluge-ui-web
opkg install deluge-ui-web
Cool. It's back up and running again. There was a slight bump during the first install attempt when python3-cryptography - 3.4.8-2a refused to install, but after running package update and upgrade again, it finally cooperated on the next attempt.
Many thanks for the fast help!! Much appreciated.
