Devices attaching to backhaul channel
Hardreef
Looking for some advice here. Have an AiMesh network set up with a GT-AX 11000 as the router and RT-AX88U as an access point. Both routers have the latest firmware. Setup was pretty easy with no real issues. Since the Primary router is a tri-band, AiMesh set up the 5ghz gaming band as a dedicated backhaul channel (or so the software tells me) but I still have devices attaching to this network. Is that normal or is there something wrong with my setup?
Thanks in advance for any recommendations.
I actually returned the AX because it began dropping both the 2.4 and 5 ghz networks. Fingers crossed that the AX11000 continues to work well.
D How Can Wifi Devices Connect to a Router NOT Broadcasting SSID? ASUS Wi-Fi 5
