Dhcp 90 option
nofear
I currently own the rt ac-88u I see that there is the option dhcp 60 and 61 I wanted to know if it is possible to add the option dhcp 90..I know that you are not there for the needs of each person but if you could just make a gesture I would love to. thanks in advance and sorry for my english ..
Welcome to the forums @nofear.
I am not aware of any way to add option 90 to the stock firmware. However, if you are open to installing Merlin's custom software on your router, then adding option 90 via /jffs/configs/dnsmasq.conf.add script is very easy.
Edit: Forgot to mention, the other thing to consider is if either the stock version or Merlin version of dnsmasq supports option 90 (authentication). Just because it is in the white paper does not mean the specific implementation supports it.
/sbin/udhcpc -i br1 -p /var/run/udhcpc0.pid -s /tmp/udhcpc -O33 -O249 -V sagem -x "0x4d:2b46535644534c5f6c697665626f782e496e7465726e65742e736f66746174686f6d652e4c697665626f7833" -x "0x5a:00000000000000000000006674692f**************".
i just have to write this or the whole script
Could you explain to me the procedure so that I can apply this tutorial ... thank you in advance
It's not a tutorial. The udhcpc command is hard coded into the firmware. It can't be changed with a script. You would need to compile your own custom version of the firmware.
