DHCP-data shared unauthenticated in login-view
Robert S.
Hello!
For the record i'm currently running Asuswrt-Merlin 380.57_0 on a Asus RT-N66U.
I noticed something strange when inspecting the source of the login screen.
The DHCP leaseinfo was showing as an array in javascript. I wouldnt say that this is critical, but as a user of this firmware i would like to not share my LAN-devices unless authenticated. Se the url for printscreen.
https://imgur.com/JbDDSoU
I don't know why this is showing public, but i assume that this code is used when authenticated but its still showed even if not logged in. Is this supposed to be like this?
Anyways, thumbs up for an awesome firmware. I really like it a lot :)
Best regards, Robert.
Interesting, and perhaps a big deal if the guest network is enabled - actually a really big deal if the guest network is enabled, as it shows topology of the attached clients...
I don't think this is RMerlin's code, this is likely part of Asus...
I hope you are right.
Anyone that is running native Asus firmware, or has the time to check this?
Or could we get a response from the author himself? :)
I am not sure if this poor guy is running native or Asuswrt, but the DHCP-info is showing here.
77.37.228.208:8080/Main_Login.asp
I found this via Shodan.io btw.
(If you havent checked it out you should. A giant database of portscan of almost all IPv4 adresses that can be used for analysis, fun and games)
Interesting...
I've checked some more, it looks like this is in Asus-firmware.
But shouldnt this be fixed in Asuswrt? :)
Can we get a comment on this from the author?
All I get is:
GET /Main_Login.asp HTTP/1.1
HTTP/1.0 401 Unauthorized
Server: httpd
Date: Tue, 19 Jan 2016 12:26:06 GMT
WWW-Authenticate: Basic realm="RT-N66U"
Content-Type: text/html
Connection: close
<HTML><HEAD><TITLE>401 Unauthorized</TITLE></HEAD>
<BODY BGCOLOR="#cc9999"><H4>401 Unauthorized</H4>
Authorization required.
</BODY></HTML>
Am I doing it wrong?
I am running john's fork.
All I get is:
Server: httpd
Connection: close
</BODY></HTML>
I never switched from the http based logon used in the fork to the token based logon used in the later firmware levels.
BTW...if you follow the code, they use this to determine if the logon is being made from the local lan by checking the logon ip against the valid lease ip's. It's Asus code, so any questions should be raised through the Asus support channels.
Thanks for the answer!
I understand. I think ill just switch to logging in to my router via VPN rather than having WAN access activated.
Sorry for directing this bug in your direction, you are clearly not responsible for this.
Are you planning to correct this in your fork by the way?
Correct what?:confused: My fork doesn't use this logon code, and I don't plan on moving from the http based logon.
Hmm sorry, i think i have misunderstood.
As said earlier i'm running Asuswrt 380.57 on my RT-N66U.
Screenshot of the dashboard: http://imgur.com/gtaiFAr
My loginscreen looks like this: http://imgur.com/HGiz5Fu
In the HTML-source of this loginscreen the whole DHCP lease-list is shown.
Screenshot: http://imgur.com/HIaljgM
I hope that i have installed the firmware correctly. Heres how i did it:
- I've downloaded the firmware from the Mediafire-source: https://www.mediafire.com/folder/bkfq2a6aebq68/Asuswrt-Merlin
- Extracted the TRX-file
- Installed it in the form displayed like this: http://imgur.com/H05YtFI
Is this the correct way?
I understand that this is Asus that has written bad code, but shouldnt this be something to fix in Asuswrt? :)
Isnt it possible to do this check backend rather than frontend in the javascript?
I think you may want to address this question to @RMerlin, not john9527. John offers a different fork of the Asus firmware, different than the one you're using (RMerlin is the author of your current firmware). ;)
