DHCP only working on AIMesh node 2.4gHz - why?
Mastiff
This is something of the weirdest I've seen in my 20 years of having a Windows Server at home, and my 35 years of computing! When I connect anything to the main access point in my AIMesh, which is two RT-AC88U with the latest Merlin, I can't get DHCP, and requests time out on ipconfig /renew. If I do that while connected to the node's 5 gHz network, I see the same. But if I connect to the node's 2.4 gHz network, it works!
I have set up a new server this week, going from Windows Server 2016 to 2019, and if I reboot into the old setup, everything works. On wired network it works all the time. So something's different in the setup, but I can't imagine what, and why the mesh is the only thing that notices it. I have of course done more reboots and restarts than I care to think of this weekend, and I have gone thorugh the DHCP setup of the server several times, without finding anything. Does anybody have a suggestion to what I should try? I will probably try to reset the server's DHCP service and set it up all again, but I doubt that will do anything since it works on the wired network.
The solution was no less weird! I saw a kink in the network cable that went from the server to the main AIMesh AP and tested with another cable, just to make sure. And suddenly everything works! :confused: I can understand most of the stuff not working because of a bad cable, but only the one band no the AIMesh NODE working, and no bands on the AIMesh AP is totally beyound my imagination. It's not"remembered" either, because I did several DNS cache flushes and resets of the wireless network, so it can't possibly have remembered anything. Well, at least it's working...and I get to be annoyed because a bad cable cost me hours of work! :D
Yes, when things don't make sense, start at the beginning and work slowly/methodically while testing at each step in the process.
Glad you found the solution at last. :)
Good catch! Someone told me once that 99% of all networking problems are cabling... we were using arcnet/coax. Probably not fully true but it stuck with me and keeps me checking interconnects first when troubleshooting oddness.
OE
Well, that error wasn't everything. Even with a new cable DHCP doesen't work on the main AP's 2.4gHz! :confused: It works on both the node's channels and the AP's 5gHz, but not on the 2.4. And I'm out of ideas...
