DHCP reservations: easiest way to export (from one Asus router) and import (into another router) ?
develox
As per title: playing with the new AC86U I want to put in place of the AC5300, what's the quickest/easiest way to clone the (long) DHCP reservations list I have in the latter ?
I believe it would work the same for Merlin, except the relevant nvram variable is dhcp_staticlist.
If you're using add-ons look here:
Otherwise check this one out:
I believe it would work the same for Merlin, except the relevant nvram variable is dhcp_staThaaaaticlist.
Thanks @eibgrad , I thought it could be risky to mess with nvram, but I'll give it a try then.
