dir-890l specs are wrong
even so d-link products are bad in general. Bad hardware and firmware and most importantly bad security.
gotta love the dlink haters
how does it have bad hardware , its all broadcom
CPU1: Broadcom BCM4709A0(1 GHz, 2 cores)
FLA1: 128 MiB (Spansion S34ML01G100TFI00)
FLA2: 32 MiB (Macronix MX25L25635FMI-10G)
RAM1: 256 MiB (EtronTech EM6GD16EWXC-15H)
Expansion IFs: USB 2.0, USB 3.0
USB ports: 2
Serial: yes
WI1 chip1: Broadcom BCM43602
WI1 chip2: Broadcom BCM43602
WI1 802dot11 protocols: an+ac
WI1 MIMO config: 3x3:3
WI1 antenna connector: U.FL
WI2 chip1: Broadcom BCM43602
WI2 802dot11 protocols: bgn
WI2 MIMO config: 3x3:3
WI2 antenna connector: U.FL
ETH chip1: Broadcom BCM4709A0
Switch: Broadcom BCM4709A0
LAN speed: 10/100/1000
LAN ports: 4
WAN ports: 1
and what are you referring to about security or are you referring to earlier dlink routers
the router doesn't have 512mb of ram, D-link said ram is 256mb of ram.
correct according to https://wikidevi.com/wiki/D-Link_DIR-890L_rev_A1
bad hardware as in the parts other than the main chips itself, like how it is designed by hardware (components used, motherboard design, etc). Some actions by dlink have also been against security, just search the forum to see yourself. Even i have seen first hand how vulnerable dlink routers are. They even store your passwords as plaintext. They even leaked their firmware keys.
All routers come with the same specs of hardware so you wont see a BCM4709A0 with 512MB or 1GB of ram. Its why i prefer higher end routers as they have replaceable ram and usually come with better hardware.
While dlink does update their libraries i am still not convinced that new dlink routers are secure.
Thanks for pointing out the error. I'll get it fixed shortly.
It is better to PM or email me with corrections. I don't read every post or thread.
Unfortunately, so do many other SOHO router manufacturers, including Asus :(
thats really bad, but its a good thing i dont use consumer routers as routers. i do know that at one point mikrotik did store passwords as plaintext and winbox being their weak link but they fixed all that As long as you still arent using routerOS 3 . The consumer brands being in business way longer with way more resources still havent fixed it even though they use linux as a base. The issue with dlink isnt just about storing passwords as text but also being able to retrieve them without any sort of authentication like using a url link on the router.
What really bothers me is that all these brands being an alternative to what ISPs offer cant do any better than them and yet router prices just keep increasing.
