Disable Net HW acceleration
  • Thread starter Thread starter Deleted member 62525
  • Start date Start date
D
Guest
I am on latest Marlin release on RT-86U running AMTM, Diversion and SkyNet. I have Flow Cache enabled but need to keep HW Net acceleration disabled since it may break Skynet. After each reboot both are enabled and I am forced to run nvram set runner_disable=1. What is the best way to disable it somewhere on startup? Can I do it in firewall-start script?
cheers
Mark
Why should hw acceleratio break skynet? Running like that since I have my router oO
cheers
Mark
Skynet won’t break NAT acceleration level 1 and 2. I have been running this setup for a year without issues.
Sent from my iPhone using Tapatalk Pro
There are few threads discussing it but my understanding is that asus nat hw acceleration is a hack into kernel and this is or may not be compatible with Skynet.
I don’t see any advantage from performance side to use it and I’d like to disable it on every reboot.
If this is the case you may need to put these 2 lines in init-start:
nvram commit
Or simply turning on Parental Controls, Trend Micro, Adaptive QoS or STP to force NAT acceleration level 2 to turn off
