AX86UWhy?
You didn't say what router model.
Also, for gaming, do you recommend I overclock?Why?
Pretty sure you can ... https://www.snbforums.com/threads/o...t-merlin-378-56_2-rt-ac68u-and-rt-n66u.28043/Overclock what? The router? Not possible.
Pretty sure you can
Also, do you know the SSH code for disabling Spanning Tree on the ax86u stock?
Does anyone know the SSH code to disable STP in the stock firmware?
I ran that nvram grep command and nothing happened![]()
Performance Issue with 1 Gigabit an Router RT-AC68U
OK folks, here is the last thing that you can check and was not described here. Log in using SSH to your Asus router and hit the command: # nvram show | grep stp size: 56434 bytes (9102 left) lan_stp=1 lan1_stp=1 You'll see two variables related to Spanning Tree Protocol (STP) set to 1. Some...www.snbforums.com
It works. I have the RT-AX86U with stock firmware and it works.I ran that nvram grep command and nothing happened
Speeds up the router a little - I think it enables another nat accelWhat is this "fixing"?
No it doesn't. Those posts you are quoting are from years ago and refer to a completely different router with different hardware and a completely different generation of firmware.Speeds up the router a little - I think it enables another nat accel
Merlin confirmed himself and I’ve ran speed tests and it gives me a boostNo it doesn't. Those posts you are quoting are from years ago and refer to a completely different router with different hardware and a completely different generation of firmware.
Where did Merlin confirm this? Link?Merlin confirmed himself and I’ve ran speed tests and it gives me a boost
That's a post from 2015!![]()
Enabling Hardware Flow Acceleration (Level 2) in AC87U
Howdy, After several configuration attempts, I have determined that using my ASUS AC87U downstream of my Google Fiber Box is the best configuration option I have. Google Fiber users can read this thread here for how I configured my router for a "Fiber-Box Free" configuration and why I chose to...www.snbforums.com
Thread starter | Title | Forum | Replies | Date |
G | NextDNS on Stock firmware | ASUSWRT - Official | 5 |
Welcome To SNBForums
