Diversion Diversion 5.5 - the Router Ad-Blocker, March 22, 2026
I'm using a small screen - notebook. Besides, I don't know what you need other from me to hit F12 and post some info. I guess I'll just have to wait for someone to give me some pointers.
F12 opens a window with any browser errors for the current webpage.
Great help.
Maybe these errors mean something
Uncaught Mismatched anonymous define() module: function(e){return t(e,window)}
and
https://******.****.***:8443/require/require.min.js:12
Diversion 5.4.2 is now available
  • Adjusted length of visible Firmware version number in header.
  • Adjusted confusing wording of blocking file update error text.
  • Built in extra backup logic to fall back to should the blocking file fail to update.
Have you had a chance to investigate the Diversion web UI issues with 3006.102.3 firmware? You indicated that you might take a look after the final was released. I still encounter the issue, but not 100% of the time. Here is the issue as well as the browser console error. Thanks.
Still seeing this error in the router's gui:
Which, I believe, is causing this:
Luckily I can use it fine over CLI ;)
Jynx @visortgw
I totally forgot about that :mad:
Sadly, there is still no final release for my GT-BE98 available. The bright side is that I likely still will be able to track down the cause of it.
It looks like there were a lot of changes to the order of the javascript loading with 102.3, putting jquery.js at the top of all others. No idea if this will break 388 versions or not...
Diversion 5.4.3 is now available
  • Fixes incomplete display of Diversion WebUI page for routers on 3006.x firmware. Thanks @visortgw and @Ripshod for reporting.
  • Correctly displays the blocked domains count in Diversion WebUI page when FS (fast switch) is enabled. Thanks @joe scian for reporting.
I just confirmed @thelonelycoder's fix for the 3006.x Diversion web UI. Thanks!
Maybe the server is temporarily down atm? Got these errors today. No biggie anyway, I'll check the updates later.
1 open Diversion 5.4.3 upd err
m menu amtm uu force update upd err
! Diversion: diversion.ch unreachable
! using fallback server diversion.ch
! amtm: diversion.ch unreachable
Update(s) aborted, could not retrieve version
I updated this morning and it was unusually slow, so maybe there was an issue with the server. Definitely worth trying again.
Can I add an allow domain just for my alternate blocking file (minimal)? While the medium list is great for for home use, we also need to use work pcs and for these even with minimal there are various 'neededforwork.com' sites that are blocked. I can see how to add these to the whitelist, but this then applies to both lists. What have I missed?
What have I missed?
Nothing. The allowlist applies to both blocking lists. I may add such a feature in a future release.
