dlna dies after 10 minutes
baos
Following the March 10th commit My smart tv can no longer stream videos for longer than 10 minutes. After that the dlna needs to be reset which I do by logging into the router and hitting apply without changing any options.
What brand is your smart tv? Maybe philips? I have this issue with my philips tv only that in my case i need to restart dlna every 20minutes. However i did find a fix for this problem (atleast for my case) in order to watch video normally through tv I just have to launch it with mobile app and not with tv remote. It's probably a bug in philips software but a really strange one.
It worked fine previous to the March10th commits. I was thinking it could be associated with miniupnp maybe?
discovered this:
# unused rules cleaning.
# never remove any rule before this threshold for the number
# of redirections is exceeded. default to 20
#clean_ruleset_threshold=10
# clean process work interval in seconds. default to 0 (disabled).
# a 600 seconds (10 minutes) interval makes sense
clean_ruleset_interval=600
going to tweak it up and see what happens. Also can't seem to figure out how to get it to log.
In my case DLNA server was dissapearing after 10-15 minutes and appearing back randmonly. The cause was multicast_snooping so I disabled it adding this to services-start:
echo 0 > /sys/class/net/br0/bridge/multicast_snooping
M Minimum crontab resolution 2 minutes? Asuswrt-Merlin 7
