DLNA Media not working correctly
anthr4x
I need some help!! I've been trying for few days to determine why some of the files stored on my router HDD don't show on my Samsung TV. I recently formatted my WD 2TB HDD with ext3, I try with another HDD that is also format with ext3. After losing all my files "movies" :( I realized the HDD wasn't the problem. So I decided to downgrade the firmware from 354 beta to 270 with no success of fixing the DLNA problem. I also have changed the permission of the drive from 755, 777, ect., deleted miniDLNA data, changed Media Directory, well you name it.
Here is the log i recently got, as you can see there is not a lot of files to prevent DLNA of reading the files.
[2013/04/26 02:19:34] minidlna.c:907: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.2].
[2013/04/26 02:19:34] minidlna.c:930: warn: Creating new database...
[2013/04/26 02:19:34] minidlna.c:1013: warn: HTTP listening on port 8200
[2013/04/26 02:19:34] scanner.c:731: warn: Scanning /tmp/mnt/External2TB/Movies
[2013/04/26 02:19:35] metadata.c:741: warn: Opening /tmp/mnt/External2TB/Movies/The Last Stand 2013 1080p/The Last Stand 2013 1080p.mkv failed!
[2013/04/26 02:19:35] scanner.c:503: warn: Unsuccessful getting details for /tmp/mnt/External2TB/Movies/The Last Stand 2013 1080p/The Last Stand 2013 1080p.mkv!
[2013/04/26 02:19:35] metadata.c:741: warn: Opening /tmp/mnt/External2TB/Movies/Transformers Trilogy 2007-2011 1080p/Transformers 2007 1080p.mkv failed!
[2013/04/26 02:19:35] scanner.c:503: warn: Unsuccessful getting details for /tmp/mnt/External2TB/Movies/Transformers Trilogy 2007-2011 1080p/Transformers 2007 1080p.mkv!
[2013/04/26 02:19:35] metadata.c:741: warn: Opening /tmp/mnt/External2TB/Movies/Transformers Trilogy 2007-2011 1080p/Transformers Dark of the Moon 2011 1080p.mkv failed!
[2013/04/26 02:19:35] scanner.c:503: warn: Unsuccessful getting details for /tmp/mnt/External2TB/Movies/Transformers Trilogy 2007-2011 1080p/Transformers Dark of the Moon 2011 1080p.mkv!
[2013/04/26 02:19:40] scanner.c:806: warn: Scanning /tmp/mnt/External2TB/Movies finished (1 files)!
[2013/04/26 02:19:40] playlist.c:125: warn: Parsing playlists...
Your help in this matter is greatly appreciated
Did you get media files from another drive or downloaded with transmission directly to disk? My guess, the files are only partial downloaded and you should set "rename-partial-files": true in settings.json.
If minidlna scanner detects a new mkv file and is not 100% downloaded than you get this error.
Give us more details.
Thank you for your reply.. I do download files directly to my HDD using transmission, it is also set as .part for incomplete files. I have different directories for my downloads, incomplete, complete and watch. A different folder for the finished files that I manually move ones are in the complete folder.. btw I watch "The last stand" movie directly from the router HDD not utilizing DLNA server, the movie played perfectly without any hiccups.
Are you using the built in minidlna or from entware / optware? because seems to be an issue with ffmpeg/libavformat.
am using the web interface no changes to minidnla
I started to download more files with different format. The majority of the problem are mkv files. BTW I changed the firmware back to 354.28 and formatted the HDD to ext2 2 partitions one of 2gb for asus config files like entware
[2013/04/26 10:48:14] minidlna.c:1017: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.2].
[2013/04/26 10:48:14] minidlna.c:1040: warn: Creating new database...
[2013/04/26 10:48:14] scanner.c:762: warn: Scanning /tmp/mnt/Media/Movies
[2013/04/26 10:48:14] minidlna.c:1123: warn: HTTP listening on port 8200
[2013/04/26 10:48:16] scanner.c:839: warn: Scanning /tmp/mnt/Media/Movies finished (1 files)!
[2013/04/26 10:48:16] playlist.c:125: warn: Parsing playlists...
[2013/04/26 10:48:56] minidlna.c:155: warn: received signal 15, good-bye
[2013/04/26 10:49:04] minidlna.c:1017: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.2].
[2013/04/26 10:49:04] minidlna.c:1040: warn: Creating new database...
[2013/04/26 10:49:05] scanner.c:762: warn: Scanning /tmp/mnt/Media/Movies
[2013/04/26 10:49:05] minidlna.c:1123: warn: HTTP listening on port 8200
[2013/04/26 10:49:07] scanner.c:839: warn: Scanning /tmp/mnt/Media/Movies finished (1 files)!
[2013/04/26 10:49:07] playlist.c:125: warn: Parsing playlists...
[2013/04/26 10:50:12] minidlna.c:155: warn: received signal 15, good-bye
[2010/12/31 19:00:21] minidlna.c:1017: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.2].
[2010/12/31 19:00:21] minidlna.c:1040: warn: Creating new database...
[2010/12/31 19:00:21] scanner.c:762: warn: Scanning /tmp/mnt/Media/Movies
[2010/12/31 19:00:21] minidlna.c:1123: warn: HTTP listening on port 8200
[2010/12/31 19:00:21] minidlna.c:155: warn: received signal 15, good-bye
[2010/12/31 19:00:26] minidlna.c:1017: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.2].
[2010/12/31 19:00:26] minidlna.c:1040: warn: Creating new database...
[2010/12/31 19:00:26] scanner.c:762: warn: Scanning /tmp/mnt/Media/Movies
[2010/12/31 19:00:26] minidlna.c:1123: warn: HTTP listening on port 8200
[2013/04/26 10:51:08] scanner.c:839: warn: Scanning /tmp/mnt/Media/Movies finished (1 files)!
[2013/04/26 10:51:08] playlist.c:125: warn: Parsing playlists...
[2013/04/26 12:56:14] playlist.c:125: warn: Parsing playlists...
[2013/04/26 13:11:13] minidlna.c:155: warn: received signal 15, good-bye
[2013/04/26 13:11:16] minidlna.c:1017: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.2].
[2013/04/26 13:11:16] minidlna.c:1040: warn: Creating new database...
[2013/04/26 13:11:16] scanner.c:762: warn: Scanning /tmp/mnt/Media/Movies
[2013/04/26 13:11:16] minidlna.c:1123: warn: HTTP listening on port 8200
[2013/04/26 13:11:22] scanner.c:839: warn: Scanning /tmp/mnt/Media/Movies finished (2 files)!
[2013/04/26 13:11:22] playlist.c:125: warn: Parsing playlists...
[2013/04/26 13:11:29] minidlna.c:155: warn: received signal 15, good-bye
[2010/12/31 19:00:18] minidlna.c:1017: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.2].
[2010/12/31 19:00:18] minidlna.c:1040: warn: Creating new database...
[2010/12/31 19:00:18] minidlna.c:1123: warn: HTTP listening on port 8200
[2010/12/31 19:00:18] scanner.c:762: warn: Scanning /tmp/mnt/Media/Movies
[2010/12/31 19:00:19] minidlna.c:155: warn: received signal 15, good-bye
[2010/12/31 19:00:23] minidlna.c:1017: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.2].
[2010/12/31 19:00:23] minidlna.c:1040: warn: Creating new database...
[2010/12/31 19:00:24] scanner.c:762: warn: Scanning /tmp/mnt/Media/Movies
[2010/12/31 19:00:24] minidlna.c:1123: warn: HTTP listening on port 8200
[2010/12/31 19:00:29] scanner.c:839: warn: Scanning /tmp/mnt/Media/Movies finished (2 files)!
[2010/12/31 19:00:29] playlist.c:125: warn: Parsing playlists...
[2013/04/26 16:37:44] minidlna.c:155: warn: received signal 15, good-bye
[2013/04/26 16:37:44] minidlna.c:1017: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.2].
[2013/04/26 16:37:44] minidlna.c:1040: warn: Creating new database...
[2013/04/26 16:37:44] scanner.c:762: warn: Scanning /tmp/mnt/Media/Movies
[2013/04/26 16:37:44] minidlna.c:1123: warn: HTTP listening on port 8200
[2013/04/26 16:37:49] scanner.c:839: warn: Scanning /tmp/mnt/Media/Movies finished (2 files)!
[2013/04/26 16:37:49] playlist.c:125: warn: Parsing playlists...
[2013/04/26 17:39:06] minidlna.c:155: warn: received signal 15, good-bye
[2013/04/26 17:39:09] minidlna.c:1017: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.2].
[2013/04/26 17:39:09] minidlna.c:1040: warn: Creating new database...
[2013/04/26 17:39:10] scanner.c:762: warn: Scanning /tmp/mnt/Media/Movies
[2013/04/26 17:39:10] minidlna.c:1123: warn: HTTP listening on port 8200
[2013/04/26 17:39:27] scanner.c:839: warn: Scanning /tmp/mnt/Media/Movies finished (2 files)!
[2013/04/26 17:39:27] playlist.c:125: warn: Parsing playlists...
[2010/12/31 19:00:25] minidlna.c:1017: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.2].
[2010/12/31 19:00:26] minidlna.c:155: warn: received signal 15, good-bye
[2010/12/31 19:00:31] minidlna.c:1017: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.2].
[2010/12/31 19:00:31] minidlna.c:1040: warn: Creating new database...
[2010/12/31 19:00:31] minidlna.c:1123: warn: HTTP listening on port 8200
[2010/12/31 19:00:31] scanner.c:762: warn: Scanning /tmp/mnt/Media/Movies
[2010/12/31 19:00:37] scanner.c:839: warn: Scanning /tmp/mnt/Media/Movies finished (2 files)!
[2010/12/31 19:00:37] playlist.c:125: warn: Parsing playlists...
[2013/04/26 23:11:14] playlist.c:125: warn: Parsing playlists...
[2013/04/27 02:23:43] metadata.c:741: warn: Opening /tmp/mnt/Media/Movies/Broken city 2013 1080p.mkv failed!
[2013/04/27 02:23:43] scanner.c:503: warn: Unsuccessful getting details for /tmp/mnt/Media/Movies/Broken city 2013 1080p.mkv!
[2013/04/27 02:25:15] playlist.c:125: warn: Parsing playlists...
[2013/04/27 16:30:30] playlist.c:125: warn: Parsing playlists...
[2013/04/27 22:55:50] minidlna.c:155: warn: received signal 15, good-bye
[2010/12/31 19:00:19] minidlna.c:1017: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.2].
[2010/12/31 19:00:19] minidlna.c:1040: warn: Creating new database...
[2010/12/31 19:00:20] scanner.c:762: warn: Scanning /tmp/mnt/Media/Movies
[2010/12/31 19:00:20] minidlna.c:1123: warn: HTTP listening on port 8200
[2010/12/31 19:00:20] minidlna.c:155: warn: received signal 15, good-bye
[2010/12/31 19:00:22] scanner.c:762: warn: Scanning /tmp/mnt/Media/Movies
[2010/12/31 19:00:22] minidlna.c:1123: warn: HTTP listening on port 8200
[2010/12/31 19:00:25] metadata.c:741: warn: Opening /tmp/mnt/Media/Movies/Broken city 2013 1080p.mkv failed!
[2010/12/31 19:00:25] scanner.c:503: warn: Unsuccessful getting details for /tmp/mnt/Media/Movies/Broken city 2013 1080p.mkv!
[2010/12/31 19:00:45] scanner.c:839: warn: Scanning /tmp/mnt/Media/Movies finished (8 files)!
[2010/12/31 19:00:45] playlist.c:125: warn: Parsing playlists...
[2013/04/27 23:01:26] metadata.c:741: warn: Opening /tmp/mnt/Media/Movies/Broken city 2013 1080p.mkv failed!
[2013/04/27 23:01:26] scanner.c:503: warn: Unsuccessful getting details for /tmp/mnt/Media/Movies/Broken city 2013 1080p.mkv!
[2013/04/27 23:01:44] scanner.c:839: warn: Scanning /tmp/mnt/Media/Movies finished (8 files)!
[2013/04/27 23:01:44] playlist.c:125: warn: Parsing playlists...
There should be some kind of fix for this problem and am sure am not the only one with this problems. I've google it and it seems to be a known issue, bug or problems with miniDLNA... the fix available that I have found are for computers running DLNA on Ubuntu and some other for linksys, netgear.
Any suggestions, help will be appreciated
What fix do you find, it's not that hard to apply the patch, just let me know.
This issue comes when you have a special character like !? on file name.
BTW, what is your exactly samsung tv model?
There is no special characters on any of the files. my tv is a UN55D6420
I couldn't find the website, I didn't save it because it wasn't related to Asus router. :( however i am currently downloading the same file from different sources or makers. maybe with this we can pinpoint why DLNA is not reading these particular files.
Here is an update of my miniDLNA, this is not including the files am downloading for this test.
BTW... 300 views on this post, only 1 person respond. TeHashX, I am thankful for your time and help!
[2013/04/28 16:10:58] minidlna.c:155: warn: received signal 15, good-bye
[2013/04/28 16:11:00] minidlna.c:1017: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.2].
[2013/04/28 16:11:00] minidlna.c:1040: warn: Creating new database...
[2013/04/28 16:11:00] minidlna.c:1123: warn: HTTP listening on port 8200
[2013/04/28 16:11:00] scanner.c:762: warn: Scanning /tmp/mnt/Media/Movies
[2013/04/28 16:11:07] metadata.c:741: warn: Opening /tmp/mnt/Media/Movies/Broken city 2013 1080p.mkv failed!
[2013/04/28 16:11:07] scanner.c:503: warn: Unsuccessful getting details for /tmp/mnt/Media/Movies/Broken city 2013 1080p.mkv!
[2013/04/28 16:13:06] scanner.c:839: warn: Scanning /tmp/mnt/Media/Movies finished (15 files)!
[2013/04/28 16:13:06] playlist.c:125: warn: Parsing playlists...
Shouting at those who look , but can't help you with the problem due to lack of knowledge about this particular problem won't encourage them to help you if have other problems that they COULD help you with.
Just saying...
The purpose is not to shout is cheering someone that can help.. is also been grateful.. just saying! but thanks for your observation
mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
proc on /proc type proc (rw)
tmpfs on /tmp type tmpfs (rw)
devfs on /dev type tmpfs (rw,noatime)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw)
/dev/mtdblock4 on /jffs type jffs2 (rw,noatime)
usbfs on /proc/bus/usb type usbfs (rw)
/dev/sda1 on /tmp/mnt/1TB type ufsd (rw,nodev,noatime,nls=utf8,fmask=0,dmask=0,force)
/dev/sdb2 on /tmp/mnt/Media type ext2 (rw,nodev,noatime)
/dev/sdb1 on /tmp/mnt/Asusware type ext2 (rw,nodev,noatime)
minidlna.conf
network_interface=br0
port=8200
friendly_name=Asus-Media
db_dir=/mnt/Media/Movies/minidlna
enable_tivo=no
strict_dlna=no
presentation_url=http://192.168.5.1:80/
inotify=yes
notify_interval=600
album_art_names=Cover.jpg/cover.jpg/Thumb.jpg/thumb.jpg
media_dir=/mnt/Media/Movies
serial=30:85:a9:6d:ac:08
model_number=1
setting.json
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 600,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1320,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": true,
"blocklist-url": "http://list.iblocklist.com/?list=bt_level1",
"cache-size-mb": 2,
"dht-enabled": true,
"download-dir": "/mnt/Media/Torrent/Completed",
"download-queue-enabled": true,
"download-queue-size": 3,
"encryption": 0,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": true,
"incomplete-dir": "/mnt/Media/Torrent/Incomplete",
"incomplete-dir-enabled": true,
"lazy-bitfield-enabled": true,
"lpd-enabled": true,
"message-level": 1,
"open-file-limit": 5,
"peer-congestion-algorithm": "",
"peer-limit-global": 250,
"peer-limit-per-torrent": 100,
"peer-port": 51413,
"peer-port-random-high": 65535,
"peer-port-random-low": 49152,
"peer-port-random-on-start": false,
"peer-socket-tos": "lowcost",
"pex-enabled": true,
"port-forwarding-enabled": false,
"preallocation": 1,
"prefetch-enabled": 0,
"proxy": "",
"proxy-auth-enabled": false,
"proxy-auth-password": "",
"proxy-auth-username": "",
"proxy-enabled": false,
"proxy-port": 80,
"proxy-type": 0,
"queue-stalled-enabled": true,
"queue-stalled-minutes": 30,
"ratio-limit": 1,
"ratio-limit-enabled": true,
"rename-partial-files": false,
"rpc-authentication-required": true,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "",
"rpc-port": 9091,
"rpc-url": "/transmission/",
"rpc-username": "anthr4x",
"rpc-whitelist": "*.*.*.*",
"rpc-whitelist-enabled": false,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": false,
"script-torrent-done-filename": "",
"seed-queue-enabled": true,
"seed-queue-size": 1,
"speed-limit-down": 1000,
"speed-limit-down-enabled": false,
"speed-limit-up": 1000,
"speed-limit-up-enabled": false,
"start-added-torrents": true,
"trash-original-torrent-files": true,
"umask": 0,
"upload-slots-per-torrent": 10,
"utp-enabled": true,
"watch-dir": "/mnt/Media/Torrent/Watch",
"watch-dir-enabled": true
All seams ok from outputs, the best file system is ext3 anyway.
Try to disable minidlna from router ui and install from entware
opkg install minidlna
rm -r /mnt/Media/Movies/minidlna
Edit minidlna.conf
nano opt/etc/minidlna.conf
/opt/etc/init.d/S90minidlna start
See if works fine, previous I had minidlna entware version with some issues after router reboot (now I'm on debian version) but try this steps first.
I can go back to ext3 is not a problem. I will do it tomorrow "later" and install minislna to the hdd directly.
Ok, here is what i did.
I formatted the HDD back to ext3, installed entware, nano and transmission. after rebooting to ensure the scripts are auto running i went and downloaded minidlna, nano conf and run the minidlna. In the hdd i only placed 2 files, same movies, same format mkv with different creator or torrent uploader. The 2 movies are display on my TV.... BUT!...... I cant play them it say "not supported file format". I previously could and have play mkv files Here is few things that might help.
/dev/sda1 on /tmp/mnt/Asusware type ext3 (rw,nodev,noatime,data=ordered)
/dev/sda2 on /tmp/mnt/2TB type ext3 (rw,nodev,noatime,data=ordered)
minidlna.conf
# port for HTTP (descriptions, SOAP, media transfer) traffic
port=8200
# network interfaces to serve, comma delimited
#network_interface=eth0
# set this to the directory you want scanned.
# * if have multiple directories, you can have multiple media_dir= lines
# * if you want to restrict a media_dir to a specific content type, you
# can prepend the type, followed by a comma, to the directory:
# + "A" for audio (eg. media_dir=A,/home/jmaggard/Music)
# + "V" for video (eg. media_dir=V,/home/jmaggard/Videos)
# + "P" for images (eg. media_dir=P,/home/jmaggard/Pictures)
media_dir=V,/mnt/2TB/Movies
# set this if you want to customize the name that shows up on your clients
#friendly_name=My DLNA Server
# set this if you would like to specify the directory where you want MiniDLNA to store its database and album art cache
db_dir=/mnt/2TB/minidlna
# set this if you would like to specify the directory where you want MiniDLNA to store its log file
log_dir=/mnt/2TB/minidlna/log
# set this to change the verbosity of the information that is logged
# each section can use a different level: off, fatal, error, warn, info, or debug
#log_level=general,artwork,database,inotify,scanner,metadata,http,ssdp,tivo=warn
# this should be a list of file names to check for when searching for album art
# note: names should be delimited with a forward slash ("/")
album_art_names=Cover.jpg/cover.jpg/AlbumArtSmall.jpg/albumartsmall.jpg/AlbumArt.jpg/albumart.jpg/Album.jpg/album.jpg/Folder.jpg/folder.jpg/Thumb.jpg/thumb.jpg
# set this to no to disable inotify monitoring to automatically discover new files
# note: the default is yes
inotify=yes
# set this to yes to enable support for streaming .jpg and .mp3 files to a TiVo supporting HMO
enable_tivo=no
# set this to strictly adhere to DLNA standards.
# * This will allow server-side downscaling of very large JPEG images,
# which may hurt JPEG serving performance on (at least) Sony DLNA products.
strict_dlna=no
# default presentation url is http address on port 80
#presentation_url=http://www.mylan/index.php
# notify interval in seconds. default is 895 seconds.
notify_interval=900
# serial and model number the daemon will report to clients
# in its XML description
serial=12345678
model_number=1
# specify the path to the MiniSSDPd socket
#minissdpdsocket=/var/run/minissdpd.sock
# use different container as root of the tree
# possible values:
# + "." - use standard container (this is the default)
# + "B" - "Browse Directory"
# + "M" - "Music"
# + "V" - "Video"
# + "P" - "Pictures"
# if you specify "B" and client device is audio-only then "Music/Folders" will be used as root
#root_container=.
minidlna.log
[2013/04/30 00:30:42] minidlna.c:885: warn: Starting MiniDLNA version 1.0.25 [SQLite 3.7.12.1].
[2013/04/30 00:30:42] minidlna.c:908: warn: Creating new database...
[2013/04/30 00:30:42] scanner.c:731: warn: Scanning /tmp/mnt/2TB/Movies
[2013/04/30 00:30:42] minidlna.c:991: warn: HTTP listening on port 8200
[2013/04/30 00:30:52] scanner.c:802: warn: Scanning /tmp/mnt/2TB/Movies finished (2 files)!
[2013/04/30 00:30:52] playlist.c:125: warn: Parsing playlists...
This is so frustrating. Can't used the router for the purpose I purchased for.
Should I try tomato?
I don't see any error in your log, maybe the movie has a codec that your tv can't handle, send me by pm a torrent file that is not working on your tv.
Sent from my HTC One S using Tapatalk 2
