Dlna
Fab30
Hi, please, i have problem with DLNA service. When i play a film, video is OK but sound is bad ->sound bursts on may films... Where is problem? THX
DLNA merely sends the file in its original form to the client. Playback issue is either with the client itself having problem with that file, or your connection not being fast enough to stream the file (which doesn't seem to be your problem since video is OK).
yes, becasue tn and router is on 1gbps eth... :( maybe tv has problem with codecs? lot of films not working :(
can i improve usb speed? i have 2TB WD disk with ntfs format, and tv is on eth...
I doubt it's a speed issue (either from USB or network), otherwise your video would also have problems.
