Twiglets
Just found & installed Version 2.1.14
- Added support for client IP address encryption in logs using IPCrypt. Three algorithms are supported: deterministic, non-deterministic with 8-byte tweak, and extended non-deterministic with 16-byte tweak.
- Enhanced pattern rule documentation with better examples.
- Fixed an issue where nil client addresses could cause crashes.
New version available with IPCrypt addition to encrypt addresses in logs.
Installed and working O.K.
Read /jffs/dnscrypt/example-dnscrypt-proxy.toml for details of new section in config file.
Full info @ https://github.com/DNSCrypt/dnscrypt-proxy/releases/tag/2.1.14
