Does default router VPN work?
chrisk
Im trying to set up the vpn on my router but it will not connect and just times out.
I read a few sites that say the vpn function does not work.
Is this true?
Thanks,
Chris
Is this true?
Thanks,
Chris
The VPN service works fine. You must ensure however that you don't have a second router standing in front of your router - many ISPs provide modem/router combos, which will essentially firewall all access to your RT-N66U. In such case, you need to find a way to put the modem into bridged mode.
Thanks, That must be my problem.
I have a att uverse modem/router but i enabled dmz-plus on that and I now have my n66 doing all the work but vpn is still a no go.
PPTP VPN relies on the GRE protocol (protocol 47). It's possible that DMZ Plus only forwards TCP/UDP/ICMP traffic but still filters out the GRE protocol.
One potential workaround is to switch to Asuswrt-Merlin or Tomato, and use OpenVPN instead, which is fully TCP or UDP based.
OK if I switch to your firmware can I restore my setting using the restore feature or do I have to reconfigure everything?
Thanks again.
Chris
Thanks again.
Chris
If coming from a recent enough version (354 or newer), there is no need to reconfigure anything. All your settings will be preserved.
