Learning55
Good afternoon Everyone.
I will say it upfront I am a newbie. Just uploaded a Merlin 378.54.2 on a T-Mobile 1900. All went well.
I am a bit confused by the log just wanted to make sure all is right. All I have done is done some portforward on Skype.
Thanks for the help, Damien
Jan 1 00:00:18 syslogd started: BusyBox v1.20.2
Jan 1 00:00:18 kernel: klogd started: BusyBox v1.20.2 (2015-06-10 22:20:53 EDT)
Jan 1 00:00:18 kernel: Linux version 2.6.36.4brcmarm (merlin@mint-dev) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 SMP PREEMPT Wed Jun 10 22:30:07 EDT 2015
Jan 1 00:00:18 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
Jan 1 00:00:18 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Jan 1 00:00:18 kernel: Machine: Northstar Prototype
Jan 1 00:00:18 kernel: Ignoring unrecognised tag 0x00000000
Jan 1 00:00:18 kernel: bootconsole [earlycon0] enabled
Jan 1 00:00:18 kernel: Memory policy: ECC disabled, Data cache writealloc
Jan 1 00:00:18 kernel: MPCORE found at 19020000
Jan 1 00:00:18 kernel: PERCPU: Embedded 7 pages/cpu @c8215000 s5472 r8192 d15008 u65536
Jan 1 00:00:18 kernel: pcpu-alloc: s5472 r8192 d15008 u65536 alloc=16*4096
Jan 1 00:00:18 kernel: pcpu-alloc: [0] 0 [0] 1
Jan 1 00:00:18 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 60416
Jan 1 00:00:18 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Jan 1 00:00:18 kernel: PID hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 00:00:18 kernel: Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Jan 1 00:00:18 kernel: Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Jan 1 00:00:18 kernel: Memory: 128MB 128MB = 256MB total
Jan 1 00:00:18 kernel: Memory: 255528k/255528k available, 6616k reserved, 0K highmem
Jan 1 00:00:18 kernel: Virtual kernel memory layout:
Jan 1 00:00:18 kernel: vector : 0xffff0000 - 0xffff1000 ( 4 kB)
Jan 1 00:00:18 kernel: fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
Jan 1 00:00:18 kernel: DMA : 0xf7e00000 - 0xffe00000 ( 128 MB)
Jan 1 00:00:18 kernel: vmalloc : 0xd0800000 - 0xf0000000 ( 504 MB)
Jan 1 00:00:18 kernel: lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
Jan 1 00:00:18 kernel: modules : 0xbf000000 - 0xc0000000 ( 16 MB)
Jan 1 00:00:18 kernel: .init : 0xc0008000 - 0xc003d000 ( 212 kB)
Jan 1 00:00:18 kernel: .text : 0xc003d000 - 0xc03a3000 (3480 kB)
Jan 1 00:00:18 kernel: .data : 0xc03ba000 - 0xc03dd000 ( 140 kB)
Jan 1 00:00:18 kernel: SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Jan 1 00:00:18 kernel: Hierarchical RCU implementation.
Jan 1 00:00:18 kernel: RCU-based detection of stalled CPUs is disabled.
Jan 1 00:00:18 kernel: Verbose stalled-CPUs detection is disabled.
Jan 1 00:00:18 kernel: NR_IRQS:256
Jan 1 00:00:18 kernel: MPCORE GIC init
Jan 1 00:00:18 kernel: External imprecise Data abort at addr=0x0, fsr=0x1c06 ignored.
Jan 1 00:00:18 kernel: MPCORE Global Timer Clock 400000000Hz
Jan 1 00:00:18 kernel: Calibrating delay loop... 1599.07 BogoMIPS (lpj=7995392)
Jan 1 00:00:18 kernel: pid_max: default: 32768 minimum: 301
Jan 1 00:00:18 kernel: Mount-cache hash table entries: 512
Jan 1 00:00:18 kernel: CPU: Testing write buffer coherency: ok
Jan 1 00:00:18 kernel: MPCORE Private timer setup CPU0
Jan 1 00:00:18 kernel: Calibrating local timer... 399.866MHz.
Jan 1 00:00:18 kernel: L310: cache controller enabled 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x7a130000
Jan 1 00:00:18 kernel: CPU1: Booted secondary processor
Jan 1 00:00:18 kernel: MPCORE Private timer setup CPU1
Jan 1 00:00:18 kernel: Brought up 2 CPUs
Jan 1 00:00:18 kernel: SMP: Total of 2 processors activated (3198.15 BogoMIPS).
Jan 1 00:00:18 kernel: devtmpfs: initialized
Jan 1 00:00:18 kernel: atomic64 test passed
Jan 1 00:00:18 kernel: NET: Registered protocol family 16
Jan 1 00:00:18 kernel: Found a AMD NAND flash:
Jan 1 00:00:18 kernel: Total size: 128MB
Jan 1 00:00:18 kernel: Block size: 128KB
Jan 1 00:00:18 kernel: Page Size: 2048B
Jan 1 00:00:18 kernel: OOB Size: 64B
Jan 1 00:00:18 kernel: Sector size: 512B
Jan 1 00:00:18 kernel: Spare size: 16B
Jan 1 00:00:18 kernel: ECC level: 8 (8-bit)
Jan 1 00:00:18 kernel: Device ID: 0x 1 0xf1 0x 0 0x1d 0x 1 0xf1
Jan 1 00:00:18 kernel: CCA UART Clock Config: Sel=1 Ovr=1 Div=48
Jan 1 00:00:18 kernel: CCA UART Clock rate 100000000Hz
Jan 1 00:00:18 kernel: bio: create slab <bio-0> at 0
Jan 1 00:00:18 kernel: Switching to clocksource mpcore_gtimer
Jan 1 00:00:18 kernel: NET: Registered protocol family 2
Jan 1 00:00:18 kernel: IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
Jan 1 00:00:18 kernel: TCP established hash table entries: 8192 (order: 4, 65536 bytes)
Jan 1 00:00:18 kernel: TCP bind hash table entries: 8192 (order: 4, 98304 bytes)
Jan 1 00:00:18 kernel: TCP: Hash tables configured (established 8192 bind 8192)
Jan 1 00:00:18 kernel: TCP reno registered
Jan 1 00:00:18 kernel: UDP hash table entries: 128 (order: 0, 4096 bytes)
Jan 1 00:00:18 kernel: UDP-Lite hash table entries: 128 (order: 0, 4096 bytes)
Jan 1 00:00:18 kernel: PCI: no core
Jan 1 00:00:18 kernel: PCI: scanning bus 0
Jan 1 00:00:18 kernel: PCI: Fixing up bus 0
Jan 1 00:00:18 kernel: PCIE1 link=1
Jan 1 00:00:18 kernel: PCIE1 switching to GEN2
Jan 1 00:00:19 kernel: PCI: Fixing up bus 0
Jan 1 00:00:19 kernel: PCI: bus0: Fast back to back transfers disabled
Jan 1 00:00:19 kernel: PCI: Fixing up bus 1
Jan 1 00:00:19 kernel: PCI: bus1: Fast back to back transfers disabled
Jan 1 00:00:19 kernel: pci 0001:00:00.0: BAR 8: assigned [mem 0x08000000-0x080fffff]
Jan 1 00:00:19 kernel: pci 0001:01:00.0: BAR 0: assigned [mem 0x08000000-0x08007fff 64bit]
Jan 1 00:00:19 kernel: pci 0001:01:00.0: BAR 0: set to [mem 0x08000000-0x08007fff 64bit] (PCI address [0x8000000-0x8007fff]
Jan 1 00:00:19 kernel: pci 0001:00:00.0: PCI bridge to [bus 01-01]
Jan 1 00:00:19 kernel: pci 0001:00:00.0: bridge window [io disabled]
Jan 1 00:00:19 kernel: pci 0001:00:00.0: bridge window [mem 0x08000000-0x080fffff]
Jan 1 00:00:19 kernel: pci 0001:00:00.0: bridge window [mem pref disabled]
