Download Maste - Download enable
Speedy1205
Hi Guys,
since yesterday I got A Asus RT-AC56U and trying to configure the download Master. Using the latest Merlin Build 374.40 but I have some difficulties with the the settings. As I need to download the files in the night (no 3G limit) I wanted to set it up to download from 1:00 till 08:00. But when I add now a file, its starting downloading (midday).
The settings I made like this:
Maybe I understand this in the wrong way ? But there I should put the time where the download should be done.... Any Ideas ?
Hi Guys,
Your settings are ok but Asus DM is buggy.
Restart router, add a torrent to download and see if is starting.
And another thing, be sure your Time Zone is correct under http://192.168.1.1/Advanced_System_Content.asp
well the reboot looks like fixed this issue. I also disabled amule and transmission as I will not need them.
Now I just checked the Loading of the Router and got this:
CPU Load Average (1, 5, 15 mins) 1.83, 1.12, 0.51
I thought its a bit too much and checked with SSH:
3506 3503 admin R 820 0.3 1 48.7 inotify
3505 3503 admin R 820 0.3 0 4.8 inotify
The first process (3506) is uses 50 percent permanent. What is those service for ?
OK its the Problem with AiCloud - Smart Sync.... So when you enable this than this process runs permanent with 50 percent :-)
