Download master supports watch-dir!
ml70
Not exposed on Asus' frontend, but disable DM, add these lines to [path]/Download2/config/settings.json
"watch-dir": "[path]/Download2/watch",
"watch-dir-enabled": true
and re-enable DM. Any torrents you drop to watchdir will be automatically started :D
When i try and use Download Master i just get "The Task allready exists" even though i have never tried that torrent before, i get the same error wih files and magnet links.
Anyone else had the same problem? :)
