Draytek Vigor 130 modem only combined with Asus RT-AC88U
rt2016
Hi Guys,
I hope you can help me out.
My setup:
Draytek Vigor 130
Asus Router RT-AC88U
Draytek should work as modem only. I managed to get the connection setup.
Draytek does have IP 192.168.1.x where Asus do have 192.168.2.x...
That worked so far fine, but when I set port forwarding nothing happen. It seems that the port I set in the ASUS router doesn't function yet.
Maybe you could help me out what I have to do then? I need the port forward for my Plex server.
br
rt2016
Draytek Vigor 130
so the first question is does your isp use pppoe or only pppoa , i assume you are on adsl or vdsl , as to bridge the modem makes it nothing but a transparent link between your exchange or node and the router you have connected behind it
once bridged you wont have the issue of dual nat which you currently have as the wireless router will then see the wan side ip address as its own and the wireless router will control everything
there are a couple of options explored in the link below
How to use PPPoE Pass-through and Bridge Mode on Vigor130?
http://www.draytek.com/index.php?option=com_k2&view=item&id=5346&Itemid=293&lang=en
but it does depend on your isp and its connection and configuration , let us know those details about type of internet and connection method and we can go from there
pete
Actually I do have ADSL but from next Thursday I will shift to VDSL.
The provider supports pppoe only.
