DSL-AC68U upload speed cut in half with firmware 3.0.0.4.386 (DSL v1.0.5.1.)
Rainman43CZ
Hello Gentlemen,
I have noticed after update from 3.0.0.4.384_81981 (DSL driver 1.0.4.9 ) to 3.0.0.4.386 (DSL 1.0.5.1.) the upload speed is cut in half. I have VDSL T-Mobile 100/10 VDSL2.
I tried version 386_38287, 386_38832, 386_39648 always with reset and clean settings.
There is faster downstream data rate achieve 100Mbps but upload speed is only 5Mbps although upstream data rate is 10Mbps. I did measuring via ASUSWRT, speedtest.net and fast.com. Constant 5Mbps.
Somebody with same issue?
Any help is highly appreciated.
Thanks / Václav
I am not sure it applies to you since I have a different router/firmware than you but my download speed was limited by exactly half
I fixed it by turning off QOS.
[Adaptive QOS > QOS Tab > Enable QOS to "OFF"]
Screenshot_2020-11-10 ASUS Wireless Router RT-AX86U - EZQoS Bandwidth Management.png
Thank you for your reply a I tried to turning off QOS and also I tried to change Upload Bandwidth from 10 Mb/s to 20 Mb/s but nothing change. Still upload is cut at 5Mb/s with 386 firmware and DSL v1.0.5.1. So I have to roll back to lasta 384 firmware.
