DSL support
thegeneralguy
What would it take to get the VDSL modems working in merlin? It seems to have some of the DSL specific makefiles and code still there, but not all of it. There's a source release that has more, and I'd be willing to do some legwork to get it working.
Any idea how to do this?
It takes a lot of work. You need the closed source binary blobs, add the build profile, and if it's not a Broadcom router you have to rewrite all the wireless client list code that I wrote, the Tools page display...
In short: it's not something that can be described in a post. It takes development work.
Well, ASUS has the DSL sources listed for my DSL-AC68U and I've been poking around them. It looks like a common codebase that supports basically everything with an extra DSL step that cat's the DSL firmware on but that's just 10min of looking.
Does ASUS/Broadcom supply the binary firmware blobs? I believe the dsl-ac68u is broadcom powered.
After spelunking more through the makefiles (haven't run these):
export DSL-AC68U := IPV6SUPP=y HTTPS=y ARM=y BCM57=y NTFS="paragon" AUTODICT=y BBEXTRAS=y USBEXTRAS=y EBTABLES=y SAMBA3=y MEDIASRV=y MODEM=y MODEMPIN=y BECEEM=y PARENTAL2=y ACCEL_PPTPD=y PRINTER=y WEBDAV=y CLOUDSYNC=y SWEBDAVCLIENT=y USB="USB" GRO=y APP="installed" BUILD_NAME="DSL-AC68U" PROXYSTA=y DNSMQ=y SHP=y NVRAM_64K=y DSLAC68U=y BCMWL6=y BCMWL6A=y TUNEK="n" BCM5301X=y DISK_MONITOR=y BTN_WIFITOG=y BCM4352_5G=y OPTIMIZE_XBOX=y ODMPID=y BCMSMP=y XHCI=y DSL=y DSL_TCLINUX=y VDSL=y DUALWAN=y USER_LOW_RSSI=y OPENVPN=y TIMEMACHINE=y MDNS=y HFS=y VPNC=y BRCM_NAND_JFFS2=y JFFS2LOG=y BCMFA=y XHCIMODE=y EMAIL=y LINUX_MTD="64" DEBUGFS=y BWDPI=y BTN_WPS_ALLLED=y TCPDUMP=y STAINFO=y SSH=y
the makefiles basically build the firmware for the dsl-ac68u then cat tclinux.bin onto them.
All necessary binary blobs should be in their GPL. You will need to to integrate them into my code tree, especially the wireless driver and the new shared/prebuild and rc/prebuild binary blobs.
