DSL support
ozziepip11
Hi there I have a DSL RT-ac88u router which in general is great. I use VPN through it which again in general is great. My only issue (and unfortunately is a very big one) is that there seems to be no way of managing what devices go through through VPN and which ones don't. For some reason Merlin firmware doesn't support DSL routers only the RT versions.
Could someone please tell me of a workaround my problem, and also confirm why/when del routers aren't/will be supported.
Many thanks
Austin
Sent from my SM-T580 using Tapatalk
Merlin doesn't support DSL routers and can't / won't do so because the modem code is closed source.
I assume "del" meant "DSL", and "rd" meant "RT".
