Dual wan failover
n85
Hi.
Im using Dual wan with RTAX55. I have an active/passive or Failover setup. Primary link is connected to WAN port and secondary link is connected to LAN1. How can I trigger a failover if I wanted to failback to my secondary link.
Unplugging the primary link from wireless router’s WAN port is not an option because this is cumbersome to handle. Also I tried the option of disabling WAN port from the web interface , but its not failing over to secondary connection.
Is therr a command/method which we can execute in the CLI/webui which could trigger the failover?
Thank you in advance.
Regards
Nishanth
