Duplicate packets from ip address
DAWOOD6283
I am trying to figure out how to duplicate packets from an IOT device that send my electricity usage to a remote server. I am testing a local server I build and want to duplicate the packets the device sends. From the router it send traffic to port 80. I just want to duplicate and forward traffic from 109.169.55.159 to 192.168.1.50.
tcp192.168.1.8164873109.169.55.15980TIME_WAIT
tcp192.168.1.8153611109.169.55.15980TIME_WAIT
tcp192.168.1.8163397109.169.55.15980TIME_WAIT
tcp192.168.1.8157259109.169.55.15980TIME_WAIT
tcp192.168.1.8156818109.169.55.15980TIME_WAIT
You can do with iptables on the RT-AC68U but you need to disable NAT acceleration otherwise it won't work. That will restrict your maximum download speed to probably less than 250Mbps. What is your current internet speed?
I only get about 210Mbps, so good there.
I tried
iptables -t mangle -A PREROUTING -d 192.168.1.81 -j TEE --gateway 192.168.1.50
iptables -t mangle -A PREROUTING -s 192.168.1.81 -j TEE --gateway 192.168.1.50
but get an error
Dont forget, the bulk of the routers CPU will be exhausted in the 250mbps transactions as well.
RT-AC68U-58B0:/tmp/home/root# iptables -t mangle -A POSTTROUTING -d 192.168.1.81 -j TEE --gateway 192.168.1.50
iptables: No chain/target/match by that name.
