sliverstorm
I'm trying to make the most of my wireless link between a EA-N66 and RT-N66U. Very large file transfers run about 200Mbps, but I'm hoping it can do better.
Stuff working in its favor:
- I am the only 5GHz access point in range
- After adjusting the router, the EA-N66 reports 100% signal quality
I logged in to the EA-N66 via telnet, and iwconfig reports a link speed of 405Mbps.
So, given the fairly good conditions, is there likely to be any more performance to be had, or 200 really all I can get out of 450?
Tips on what could be improved, aside from removing the wall? (If there wasn't a wall, I'd just use a cat-5e cable
Edit: I should have added, I am running the latest Asuswrt-Merlin. Also, I just eeked out another 1-2MB/s by overriding the 5GHz channel to the lowest available, 36. I discovered a pair of very weak stations on 157, and I figure I might as well go with the lower number channel in hopes that it improves range and thus link quality. So, now I'm at something like 210Mbps! Just 240 more to go.
