chadster766
*Warning this will void your warranty
Opening the EA9500 case:
1. Remove the 4 screws under feet and product label
2. Remove plastic reinforcement cover
3. Remove cover plate
4. Connect USB to TTL cable
Below is some serial console output:
Digital core power voltage set to 1.05V
Decompressing...done
CFE Boot Loader v0.5.1__7.14.131.35
SHMOO VER 1.13
PKID07DC06011801080000000000001A103F01000000
S30000217
00001770
RDLYW0 00000004
RDENW0 00000037
RDQSW0
0000000000111111111122222222223333333333444444444455555555556666
0123456789012345678901234567890123456789012345678901234567890123
00 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++++
01 ------------++++++++++++++++++++++++++X++++++++++++++++++++++++-
02 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++++
03 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++--
04 ------++++++++++++++++++++++++X+++++++++++++++++++++++----------
05 ---------------++++++++++++++++++++++++X++++++++++++++++++++++--
06 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------
07 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++++
08 ---+++++++++++++++++++++++++X+++++++++++++++++++++++++----------
09 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------
10 --------+++++++++++++++++++++++++X+++++++++++++++++++++++++-----
11 -------++++++++++++++++++++++++X+++++++++++++++++++++++---------
12 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------
13 -----+++++++++++++++++++++++X+++++++++++++++++++++++------------
14 ------+++++++++++++++++++++++++X+++++++++++++++++++++++++-------
15 --+++++++++++++++++++++++++X+++++++++++++++++++++++++-----------
PW0
00 ---++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++-
01 ----++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-
02 --+++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++++
03 --+++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--
04 +++++++++++++++++++++++++++X++++++++++++++++++++++++++----------
05 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--
06 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------
07 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++++
08 +++++++++++++++++++++++++++X++++++++++++++++++++++++++----------
09 +++++++++++++++++++++++++++++X++++++++++++++++++++++++++++------
10 +++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++-----
11 +++++++++++++++++++++++++++X+++++++++++++++++++++++++++---------
12 +++++++++++++++++++++++++++X+++++++++++++++++++++++++++---------
13 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------
14 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------
15 +++++++++++++++++++++++++++X++++++++++++++++++++++++++----------
NW0
01 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++++
03 -----------++++++++++++++++++++++++++X++++++++++++++++++++++++++
04 --------+++++++++++++++++++++++++X+++++++++++++++++++++++++-----
05 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++
06 -------++++++++++++++++++++++++++X++++++++++++++++++++++++++----
08 ---++++++++++++++++++++++++++X++++++++++++++++++++++++++--------
09 --------++++++++++++++++++++++++++X++++++++++++++++++++++++++---
10 -------+++++++++++++++++++++++++++X++++++++++++++++++++++++++---
11 --------+++++++++++++++++++++++++X+++++++++++++++++++++++++-----
12 ---+++++++++++++++++++++++++++X++++++++++++++++++++++++++-------
13 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------
14 -----++++++++++++++++++++++++++X++++++++++++++++++++++++++------
15 ---+++++++++++++++++++++++++X+++++++++++++++++++++++++----------
WRDQW0
00 +++++++++++++++++++++++++++X+++++++++++++++++++++++++++---------
01 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------
02 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------
03 +++++++++++++++++++++++++++X+++++++++++++++++++++++++++---------
04 ++++++++++++++++++++++++X++++++++++++++++++++++++---------------
05 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------
06 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------
07 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------
08 +++++++++++++++++++++++++X+++++++++++++++++++++++++-------------
09 +++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------+-
10 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------
11 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------
12 +++++++++++++++++++++++++X++++++++++++++++++++++++--------------
13 +++++++++++++++++++++++++X+++++++++++++++++++++++++-------------
14 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------
15 +++++++++++++++++++++++++X+++++++++++++++++++++++++-------------
WRDMW0 00000027
WRDMW0 00000025
ADDR
00 +++++++++++++++++++++++S+++++++X++++++++++++++++++++++++++++++++
Found a Toshiba NAND flash:
Total size: 128MB
Block size: 128KB
Page Size: 2048B
OOB Size: 64B
Sector size: 512B
Spare size: 16B
ECC level: 8 (8-bit)
Device ID: 0x98 0xf1 0x80 0x15 0xf2 0x16
find_devinfo: devinfo block found at 0x00180000!
Press Ctrl+C to stop in CFE
CFE version 7.14.131.35 (r612453) based on BBP 1.0.37 for BCM947XX (32bit,SP,)
Build Date: Fri Jan 22 18:07:59 CST 2016 (proc@ubuntu12d04LTS), for the EA9500 board
Copyright (C) 2000-2008 Broadcom Corporation.
Copyright (C) 2016 Arcadyan Corporation.
Flashing all LEDs ...
Init Arena
Init Devs.
Boot partition size = 262144(0x40000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1400,*800*
### RoboID=53012, vid=1 val32=0x35faf val16=0x1 ###
### RoboID=53012, vid=2 val32=0x22110 val16=0x2 ###
et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.131.35 (r612453)
CPU type 0x0: 1400MHz
Tot mem: 262144 KBytes
CFE mem: 0x00F00000 - 0x01799D2C (9018668)
Data: 0x00F601E0 - 0x00F608A8 (1736)
BSS: 0x00F608B8 - 0x00F97D2C (226420)
Heap: 0x00F97D2C - 0x01797D2C (8388608)
Stack: 0x01797D2C - 0x01799D2C (8192)
Text: 0x00F00000 - 0x00F52488 (337032)
Boot: 0x0179A000 - 0x017DA000
Reloc: I:00000000 - D:00000000
Boot version: v0.5.1__7.14.131.35
Device eth0: hwaddr 48-F8-B3-F6-49-51, ipaddr 192.168.1.1, mask 255.255.255.0
gateway not set, nameserver not set
Loader:raw, invalid tftp target filename (:)!
Could not load :: Invalid parameter
Checking CRC validity of nflash1.trx ... OK
Booting(0): boot -raw -z -addr=0x8000 -max=0xef8000 nflash0.os:
Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)
Loading: ..... 5438272 bytes read
Entry at 0x00008000
Closing network.
Starting program at 0x00008000
cfe_start: launch kernel with blue LED0 is on!
console [ttyS0] enabled, bootconsole disabled
serial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550
brd: module loaded
loop: module loaded
pflash: found no supported devices
bcmsflash: found no supported devices
The first offset=200000, 2nd offset=1f00000
Boot partition size = 524288(0x80000)
lookup_nflash_rootfs_offset: offset = 0x200000
nflash: squash filesystem with lzma found at block 33
lookup_nflash_rootfs_offset: offset = 0x1f00000
nflash: squash filesystem with lzma found at block 265
Creating 6 MTD partitions on "nflash":
0x000000000000-0x000000080000 : "boot"
0x000000080000-0x000000200000 : "nvram"
0x000000200000-0x000001f00000 : "linux"
0x00000042dba4-0x000001f00000 : "rootfs"
0x000001f00000-0x000005200000 : "linux2"
0x00000212db04-0x000005200000 : "rootfs2"
