Easy dumb cru question.
  • Thread starter Thread starter Deleted member 27741
  • Start date Start date
D
Guest
I have a cru command setup and have a few questions-
Using "/usr/sbin/cru a WOL "20 4 * * 7 /jffs/userscripts/wolscript"" resulted in the command running every day- does the N66U interpret 7 as every day instead of Sunday (0-6 is standard, I believe).
Will "20 4 * * SUN" work?
Using anything other than 0 to 6 is not POSIX compliant so I wouldn't trust it myself. That said, Busybox's cron does support some non-standard options, but not day "7" apparently:
Feb 21 16:31:00 crond[643]: user admin: parse error at 7
Looks like "sun" would be acceptable. But what's wrong with "0"?
I would use Sun, this works for all firmware releases. 0 and 7 produce unexpected results on some older releases.
I use the three letter day variant in all my scripts and never again had complaints, which I had when I was using 0 or 7.
Thanks thelonelycoder and ColinTaylor! Nothing wrong with zero- but SUN is more intuitive. I'll give SUN a shot.
