ECB6200 TV/STB Port - No MoCA???
JWadle
I am using an Actiontec ECB6200 to create a MoCA network for my TiVo boxes. To my surprise and disappointment, the TV/STB port on the ECB6200 does not seem to carry the MoCA signal. This means I can't connect my TiVo Mini that is in the same room as the ECB6200 via MoCA - I've had to run an Ethernet cable to this TiVo.
What is the point of adding a TV/STB coax port to this M0CA adapter and them not pass MoCA through this port? Ridiculous.
Doesn't the mini operate off of MOCA already from the tuner device ?
Are you running Dish or Direct TV over the same cable ?
If you need ethernet extension, use a bi-directional 5-2000 splitter ahead of the two devices.
Using the TiVo DVR to create the MoCA network requires an Ethernet cable to the DVR in addition to coax. I don't have the option of Ethernet cabling to the location of my DVR (TiVo BOLT). Therefore I have to use a MoCA adapter like the ECB6200 near my wired router to create the MoCA network.
