If you are changing the part, you have the router open anyway and are in the best position to read the part number.I want the number of this ic ..to change it
The high resolution photo will not stating anything
You have The model number
This part is already damage ..and his number isn't exist anymoreIf you are changing the part, you have the router open anyway and are in the best position to read the part number.
Router manufacturers do not release parts lists.
Thank you for your supportYou also have the model number.
EnGenius SoHo 300mbps Wireless Router - EL-ESR-1221N2 | Solwise Ltd
www.solwise.co.uk
There is nothing else I can find for you. I suggest you contact Solwise and ask them directly for the board schematics if they have it.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
