Unbound Entware+386.3
MatteoPV
I am using GNUton 386.3 on Asus DSL AC 68 U. Everything was fine, but yesterday Entware updated and since then Unbound doesn't work anymore, besides the router does strange things, it seems unstable, at startup it disconnects the wifi which it did not do before. before updating Entware it was fine
this is the reason we do not have auto Entware update. It is better do not upgrade it if not needed. Now you will need to downgrade it what is a pain (each module need to be done separately) and very often it is faster to do it from 0. Challenge is that you know something is wrong with latest Entware and need to try find alone or what for someone to investigate.
thx for posting I hope more people will read it and will not upgrade Entware at this point.
Don't count on it. Entware packages do not always look at any current configuration and simply install defaults. With every update, I have to go in and replace the configs with my custom ones (wireguard, nut, samba). Entware just slaughters them on update. I always keep backups and am ready to replace my configs as I know what is coming.
The best way to go about it with regards to Unbound is to STOP Unbound, update Entware, then run 1 Update for Unbound.
The last step should restart Unbound automatically. If not then restart manually. I also do a router reboot on the end.
I tried to force the Unbound update but then it gives me an error and it doesn't work
Maybe another script is making for the headache, just UNINSTALL and REINSTALL UNBOUND. In the end it's faster with less drama. I've had to do it this way multiple times when a hiccup makes it way in that won't resolve.
This is The Way...
I wish I had read this post prior to updating entware by rote when amtm notified me, but selecting option 1 in the unbound manager did indeed restart and update the config and Presto! unbound is working. Lost my stats, but meh...they'll repopulate before Merlin releases 386.4
I just found this thread and I have similar issues with unbound on an AC88U with 386.3. I do not know if Entware was updated, however unbound was not running anymore for the last week. I tried to update it, and afterwards (as suggested above) uninstalled it completely and tried to reinstall. In both cases I got this error message:
UPDATEing unbound
***ERROR occurred updating Entware package list
Anything that can be done to install unbound again?
Please, fell free to report about issues you've found, it's quite easy to fix.
We can't to test upgrade on all existing packages, sorry.
by chance are you getting Segmentation faults? I just upgraded to 386.3_2 and all of a sudden everything in Entware is segfaulting
after playing a bit and searching through various threads it seems that something in the entware packages is broken and there are segmentation faults. When I try to updated entware the following happens:
Package ca-bundle version 20210119m1 has no valid architecture, ignoring.
ERROR: truncating field 8 <0xf1000> to 4 bytePackage libqrencode version 4.1.1-1 has no valid architecture, ignoring.
Segmentation fault
ERROR: truncating field 8 <0x30ff50> to 4 bytePackage libqrencode version 4.1.1-1 has no valid architecture, ignoring.
Segmentation fault
and probably because of that, I am not able to re-install unbound again. anyone has an idea what can be done here? Or can I really just report the issue and wait?
