Entware memory exhausted
Marko Polo
I get this message while installing entware: memory exhausted
Entware uses separate locale-archive file independent from main system
Creating locale archive - /opt/usr/lib/locale/locale-archive
Adding en_EN.UTF-8
memory exhausted
Adding fr_FR.UTF-8
memory exhausted
locale-archive file was not created, not enough memory? Downloading...
checking endianess....
Byte Order: little endian.
--2018-07-08 09:13:29--  http://pkg.entware.net/binaries/other/locale-archive.2.23
Resolving pkg.entware.net... 81.4.123.217
Connecting to pkg.entware.net|81.4.123.217|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 2916416 (2.8M) [application/octet-stream]
Saving to: '/opt/usr/lib/locale/locale-archive'
What does that mean? df -h gives proper picture and I have enough space
Filesystem                Size      Used Available Use% Mounted on
/dev/root                33.9M     33.9M         0 100% /
devtmpfs                124.8M         0    124.8M   0% /dev
tmpfs                   124.9M      2.6M    122.3M   2% /tmp
/dev/mtdblock4           62.8M      2.8M     59.9M   4% /jffs
/dev/sda1               234.7G    131.5G     91.3G  59% /tmp/mnt/data
I feel that this message connected with that bug
This is normal, just ignore it.
