I have a rt-n66u installed with Merlin firmware installed.
I will be moving to a 3000+sq ft house and in Canada, houses are mainly made of drywall and wood (I'm sinplifying it
I want to extend the range of my wifi so that I can ensure there is wifi across the house. I'm planning to have internet directly hooked to the tv because I use chromecast and android tv for all my tv consumption.
So problem is the router will be in a corner of the house on the main floor and to extend wifi using a cost effective method, which approach should I use aside from increasing the transmitting power:
1) replacing more powerful antennas (if so, any recommendations?)
2) buying a wifi extender?
3) replace with a more powerful router?
I'm not sure which is a more cost effective approach... I'm open to suggestions!
Thanks!
Thanks!
